Author Topic: My first refurb!  (Read 5434 times)
Talisman
  • Trade Count: (+76)
Re: My first refurb!
« Reply #15 on: March 08, 2011, 01:29:44 PM »
Have you fitted the Combi grip with the thicker end as the top hand on purpose?
« Reply #16 on: March 08, 2011, 02:57:55 PM »
Buzz pointed that out to me. No, forgot which way I had it when I had it rolled up so just put it on, and that was the way it came out. Strangely, it feels rather comfortable to hold that way.
tommo256
« Reply #17 on: March 08, 2011, 03:28:19 PM »
How did you start? did you just grab the sandpaper and go or?
« Reply #18 on: March 08, 2011, 03:44:27 PM »
Got the hairdryer out on the original armour face and stickers, they came off a treat. Then stuck it in the workmate and used an orbital sander on the front. Started at Coarse grade paper and then went through medium to fine. Had to remove a few seam marks and cherries and tried to get rid of surface cracking.
Used the same technique on the edges and toe, then used a rubber block with paper in to do the back and also the corners, again going through the grades.
Fairly straightforward, just a bit time consuming, and sanding the back by hand is a reasonable amount of effort.
SkipperJ
« Reply #19 on: March 08, 2011, 06:25:50 PM »
Nice job mate! I am in the process of refurbing one of mine as well. Your tips will come in very handy!
I have finished sanding the back, still waiting for the beeswax to arrive in the mail. Did you say you used steel wool to spread it around on the back? I was going to use a hairdryer and some cloth...
CBF gave me BAD real bad!
Simmy
« Reply #20 on: March 08, 2011, 08:06:20 PM »
i pulled stickers off and big bits of wood pealed off new i should of heated it 1st lol
hit4six
  • Trade Count: (+35)
« Reply #21 on: March 08, 2011, 08:09:15 PM »
In that instance Simmy, you need to remove the stickers against the grain. Of course, across the grain and slowly is recommended.
Simmy
« Reply #22 on: March 09, 2011, 07:58:26 AM »
yer figguered that out half way through!
hardest thing is removing fiberglass tape thats been on for about 4 years!
not the clear sheet awfull fiberglass it just disintergrates in ur hand lol and clogs up the sand paper cos it turns into glue
« Reply #23 on: March 09, 2011, 08:09:40 AM »
Dave is probably the best person to answer this question, but I'd warm it a little using my hands and then only apply a small amount of beeswax using steel wool. I'd use steel wool as it's a final, very fine, abrasive and this will work better for polishing than a cloth will. All you are really doing with a cloth is buffing.
SkipperJ
« Reply #24 on: March 09, 2011, 04:46:02 PM »
Did some searching on the forum and found these tips from Andy for finishing
http://custombats.co.uk/cbforum/index.php?topic=433.0
Btw, what's the difference between polishing and buffing?
Dave, if you have any tips, do share...
Steny12
« Reply #25 on: March 09, 2011, 04:51:45 PM »
apparently if you put the hair dryer on the sheet it helps alot :P
SkipperJ
« Reply #26 on: March 09, 2011, 09:50:05 PM »
Anyone on here use this stuff?  Lord Sheraton Beeswax balsam
http://lordsheraton.co.uk/beeswax.html
Has both beeswax and cold-pressed linseed oil, plus some pine turpentine (to clean up the wood i suppose?)
Anyway, might this be a cheaper alternative to Salix bat wax?
