Author Topic: Black Cat Bats, what are they made of?!  (Read 9314 times)
Re: Black Cat Bats, what are they made of?!
« Reply #15 on: May 02, 2011, 07:46:53 AM »
The Shadows are grade 1. If you want to be strict about it, if bats have any heartwood in it, then they can only be grade 2 I believe!
But if my bat is grade 2 based on cosmetics because of the heartwood, then I for one don't care. If you base my shadow on performance the. Grade 1+++ and then some!
As far as I'm aware black cat only do grade 1 with shadow and voodoo. Although they do a lower grade joker!
Black Cat Cricket
« Reply #16 on: May 02, 2011, 10:51:38 AM »
Spot on Pete.
As we all know grading is only an opinion, JS Wrights' system of grading is the industry standard, but only because they supply a very large chunk of the world's English Willow.  Black Cat has its own willow, and so we grade it ourself.
We are more stringent than Wrights (and others) in some regard, less so in others.
An example being similar to your bat, Pete- if a cleft has 18 straight grains and half an inch of heartwood on the edge, we'd class that as Grade One.
m4ttc
« Reply #17 on: May 08, 2011, 07:33:58 PM »
I have 2 Black Cats, a Joker and a Shadow and I can honestly say in the performance is top notch. This is based on owning top bats from my first GN100 Scoop back in 1981.
Buy one, you will not regret
« Reply #18 on: May 08, 2011, 09:37:15 PM »
I second what matt said expect date and bat for me its 2009 and plain Pakistani bat :P
« Reply #19 on: May 09, 2011, 06:27:48 AM »
Going back to the title, I'm not sure what they are made of, but when you use one you call forth the power of ten tigers.....
