RIP or TLC???????
Author Topic: RIP or TLC???????  (Read 2112 times)
Liam-SCCC
RIP or TLC???????
« on: April 27, 2011, 08:14:12 PM »
My beloved bat broke tonight, the best bat I've ever had started to sound really weird and has cracked from under the binding and down the back a bit.
Just want to know if there is any way to save it whilst retaining feel.
Pics up in a second.
Top Score: 102*
Best Bowling: 7/29
Liam-SCCC
Re: RIP or TLC???????
« Reply #1 on: April 27, 2011, 08:21:20 PM »
All of the pictures are the same but some are better than the others
and down the other side
Top Score: 102*
Best Bowling: 7/29
Liam-SCCC
« Reply #2 on: April 27, 2011, 08:49:20 PM »
Anyone able to advise?
Top Score: 102*
Best Bowling: 7/29
Perkins17
    • GM Cricket
« Reply #3 on: April 27, 2011, 08:50:36 PM »
tlc need to open the crack and glue it but not sure on how long it will last :P
« Reply #4 on: April 27, 2011, 08:50:56 PM »
is that the champ???
Got a similar problem with my Private Bin mate keep glueing after every 2 or 3 games unfroutunatly
Watsontotty
« Reply #5 on: April 27, 2011, 08:51:42 PM »
don't see why it wont repair and last for a fair while
Liam-SCCC
« Reply #6 on: April 27, 2011, 09:02:24 PM »
It is the champ...
My mate has offered me his pretty much new GM Luna 808 for £100, I will have a go with that.
The bat still goes, but sounds horrible
Top Score: 102*
Best Bowling: 7/29
« Reply #7 on: April 27, 2011, 09:19:39 PM »
Funny enough I have been to Kippax today with the same problem and it's repairable with glue. Mine is handle related and I need the handle to break first, but a friend had the same problem as yourself and they replaced the handle and glued it up. The PVA glue is stronger than the wood, so it should last if properly fixed - the glue needs to get all the way into the crack or the crack will just continue down the bat.
Chris reckoned it's caused by the binding on the bottom inch of the handle not being tight enough and allowing flex.
Liam-SCCC
« Reply #8 on: April 27, 2011, 09:32:52 PM »
I have just re-glued the bottom couple of lines of binding
Top Score: 102*
Best Bowling: 7/29
Liam-SCCC
« Reply #9 on: April 27, 2011, 09:34:47 PM »
The top shoulder of the bat I can pull away quite a bit. So could get glue in the top but not down to the bottom of the crack
Top Score: 102*
Best Bowling: 7/29
Talisman
  • Trade Count: (+76)
« Reply #10 on: April 28, 2011, 09:46:57 AM »
Rehandle, cut the existing one out, open up and glue the breaks and then rehandle, the breaks will be caused by the handle fitting anyway so no point in keeping it in.
Liam-SCCC
« Reply #11 on: April 28, 2011, 06:47:20 PM »
How much would a rehandle and repair be mike? Would I lose the stickers I paid £27 for!?
My mate has offered me his nearly new Luna 808 for £100
Don't know whether to repair or replace
Top Score: 102*
Best Bowling: 7/29
Canners
  • go hard or go home
« Reply #12 on: April 28, 2011, 06:52:42 PM »
if its your fave bat, get it repaired
Liam-SCCC
« Reply #13 on: April 28, 2011, 07:02:44 PM »
The crack measures 16cm out from under the binding and rather than going straight down it seems to diagonally into the blade. As if it slice the top layer of wood off when it goes
Top Score: 102*
Best Bowling: 7/29
