Pages: 1 2 [3]
Author Topic: Benefits of a Trigger Movement?  (Read 8417 times)
Re: Benefits of a Trigger Movement?
« Reply #30 on: August 20, 2012, 05:02:46 PM »
i just dont see how you can dismiss the trigger movement when all the internationals do it
having played agaisnt very fast bowlers myself, i can tell you that without the back and across trigger i would have had no chance against those quick bowlers.
Buzz is right in that most batsmen should ditch it ........ but only becasue they dont do it right and it causes some pretty serious balance issues.
I agree, I also agree with your technical points about when to trigger. although typically I prefer the tigger to be complete before the bowled gets to his "coil" position. I am not sure if that is the same as what you have said.
Also remember a trigger doesn't have to be a foot movement.
most of the batsmen I see don't face the quality of bowling that merits a trigger and my experience on this forum is that most batsmen would benefit from being still rather than a poorly executed trigger, which is why a suggest you stand still at the crease.
again this is just a repeat of what is above.
as for playing spin, look at how amla plays it and how VVS played spin and that will give you some ideas!
« Reply #31 on: August 20, 2012, 05:08:09 PM »
i think you hit the nail on the head buzz
a trigger or pre delivery movement needs to be done and completed before the bowler is in the air and if not then it will cause more harm than good.
i think it needs to be taken more seriosuly thanjsut rocking up for a game and deciding to inorporate a trigger, its something that needs doing over a winter and needs watching on a video to see if everything is correct
ammo
« Reply #32 on: August 21, 2012, 09:42:24 AM »
I move my back foot back and across with my front foot resting on its toes this allows my front foot to move anywhere and saves time whe facing a short ball.
I just can't stand still when a bowler is running in i need to move... :-[
Pages: 1 2 [3]
