Author Topic: 2nd attempt  (Read 2383 times)
Bez013
2nd attempt
« on: August 07, 2011, 04:41:39 PM »
Having already worked on one part made I finally got round to ordering a couple of part made clefts from Hell4Leather and the first one I've tackled is a Grade 3 cleft, I have a Grade 1 to have a go at next weekend.
The first bat I made with planes and spokeshaves only and didn't try to concave, this time round I have used a straight drawknife and a coopers hollowing drawknife, I am much happier with the outcome in terms of the shape of the bat but don't know if it was the use of the drawknives that made the difference or perhaps making sure not to make the same mistakes as first time round.
One observation of using a drawknife is that it is very easy to take more willow out than you anticipated.....the area near the splice is much thinner in the spine that I would have liked but got a big piece.  That said the whole process took me about 2 hours less than first time!
I was aiming for a low middle, not really worried about edge size and the dead weight wasn't really a concern, just got it to a point where I liked the pick up.  It weighs in at 2lb11oz in current state which has the handle bound and gripped, I may add a facing and glue to the toe later.
Here are a few pictures:
The final picture is a side by side with my first effort which weighs in at 2lb13oz so you can get an idea of the difference between the 2!
Comments good or bad are welcome.
RossViper
  • What noise does a cow make?
    • My Excel Blog!
Re: 2nd attempt
« Reply #1 on: August 07, 2011, 05:43:09 PM »
Not bad mate! Is it a bit bottom hevey?
Is there a mark on the face it looks like its got a black mark on it.
Bez013
Re: 2nd attempt
« Reply #2 on: August 07, 2011, 06:05:02 PM »
Cheers.
It is a low middle so slightly bottom heavy but I use a 2lb15oz bat at the moment so I don't find it heavy and I shaped it to where I liked the pick up, I'll get a few team mates to give it a go and see what they think.
Do you mean the mark near the splice or the colouring running up the bat?  There is a mark near the splice which I tried sanding and couldn't get rid of.....also in the photo there is also some darkness running the length of the bat but I think that is my use of the flash as it doesn't look that dark in natural light.
thaman303
Re: 2nd attempt
« Reply #3 on: August 07, 2011, 06:46:49 PM »
nice attempt, edges looks a bit off set though. I will start my second project soon :)
Bez013
Re: 2nd attempt
« Reply #4 on: August 07, 2011, 08:24:24 PM »
Thanks, both bats I ended up taking more off the edge than I orignally intended, bit of a slip with the drawknife on this one.
Good luck with your second.
Ryan
  • Trade Count: (+17)
Re: 2nd attempt
« Reply #5 on: August 07, 2011, 08:42:45 PM »
is the spine off centre?
Ryan
Re: 2nd attempt
« Reply #6 on: August 07, 2011, 09:10:49 PM »
The second photo is of the face - I initially thought it was of the back and the spine was way off centre.
Apologies if this isn't what you thought.
yeah must be the shadows on the face of the bat...
