Author Topic: Mad oiling ?  (Read 3528 times)
Re: Mad oiling ?
« Reply #15 on: November 17, 2011, 09:47:31 AM »
Various different opinions:
Quote
Oiling the bat properly will make sure that the wood becomes supple and this means that when the knocking in process starts the face & edges of the bat will dent rather than crack.
- Jon Gibson Cricket Coaching
Quote
All natural faced bats MUST be treated using raw linseed or a specialist cricket bat oil. The main purpose of oiling is to maintain moisture levels within the blade, and hence reduce the chances of cracking and splitting.
- Kookaburra
Quote
Raw linseed oil should be used to moisten the surface of the bat and enable the fibres to become supple and knit together, forming an elastic surface. This is more likely to stretch on impact, rather than crack. Raw linseed oil is used, as it stays moist for longer than boiled linseed. About a teaspoonful should be applied to the surface of the bat
- ABC of Cricket
Quote
The purpose of oiling your cricket bat is to help prevent the wood from drying out and becoming brittle, it also helps to soften and bind the surface fibres of the willow during the knocking in process. By oiling the toe you are helping to prevent water ingression that could lead to the toe cracking and the face peeling.
- Cricketspecialist.co.uk
Re: Mad oiling ?
« Reply #16 on: November 17, 2011, 09:54:59 AM »
I give my bats one light coat and refresh about once every 6 months.
I once over oiled a bat and it just sounded dead. Anymore than 1 or 2 coats is asking for trouble in my book. Perhaps the bats are dried out more than most?
Re: Mad oiling ?
« Reply #17 on: November 17, 2011, 10:09:44 AM »
3 coats max imo
steelcouch
Re: Mad oiling ?
« Reply #18 on: November 17, 2011, 11:43:19 AM »
Too much oil can male the bat "wet" and deaden the responsiveness of it.
Six coats sounds too much to me.
Although completely unscientifically i did put a lot of oil on one bat and really knocked it in and it went like a steam train. I THINK it was partly because having lots of oil in the knocking in process produced a really good surface and that made an average bat really good.
I only oil a bit these days, but....
