Pages: 1 ... 4 5 [6]
Author Topic: New designs  (Read 22661 times)
roco
Re: New designs
« Reply #75 on: February 13, 2012, 05:43:31 PM »
It's definatley worth the drive but can't buy anything there unfortunately but we did (and by we I mean Pete) did try to sneak trotts bat out but were caught
ProWannabe88
Re: New designs
« Reply #76 on: February 13, 2012, 05:48:39 PM »
Caught..... Useless you man  :D is there not a shop there??
MD2812
  • Hi, I'm Joe
Re: New designs
« Reply #77 on: February 13, 2012, 07:20:25 PM »
I've had this idea for a while, and was going to try it on an old bat.
What about on the edges small grooves cut in at approximately 45 degrees (open to variation) from face of bat to back. (Higher at the face end) spaced roughly an inch apart
The effect of this could be that balls which clip edges are directed towards the ground (sorry bowlers and slips).
Not sure on the legality of this
A bit innovative like when woodworm put scoops out.
Anyone with better IT skills than me (MS Paint amateur here) might be able to notch up a design.
David Bacon B3
  • Aka Streaky - B3 bat geek (designer)
Re: New designs
« Reply #78 on: February 14, 2012, 11:54:55 AM »
In celebration of my 20th post I 've decided to add a picture to my profile - but can not seem to do it!!
Any suggestions?
David
"Quality is remembered long after the price is forgotten" Sir Henry Royce
Follow me on twitter - Dr_DBacon https://twitter.com/#!/Dr_DBacon
Colesy
Re: New designs
« Reply #79 on: February 14, 2012, 11:56:38 AM »
Have you tried using a URL or your own picture? I had some issues using a URL when I first joined.
I'll go through the process now to see what could go wrong.
Re: New designs
« Reply #80 on: February 14, 2012, 11:59:24 AM »
The other side to this is that you introduce additional weakness into an already weak part of the bat. What is more likely to happen is that the edge of the groove will get broken off and the ball will still carry to the catcher, unless you have some very thick or very strong wood on the edges.
