run out by the bowler in his delivery stride?
Author Topic: run out by the bowler in his delivery stride?  (Read 3841 times)
Re: run out by the bowler in his delivery stride?
« Reply #15 on: February 22, 2012, 02:25:47 AM »
Law 38.2b is clearly counter your statement on the Lords website. Once in the delivery stride the ball must subsequently touch a fielder before the wicket is put down for the non striker to be given out.
Yes I agree, my understanding was that once a bowler is in his delivery stride he/she cannot run a batsman out the mankad way, Delivery stride being the point of jump in the run so if you come running in and don't jump or turn your arm over then you can run them out... only difference now is that you dont have to warn the batsman
sgcricket
« Reply #16 on: February 22, 2012, 07:32:34 AM »
it is not law 38. here is the link to it http://static.icc-cricket.yahoo.net/ugc/documents/DOC_BB1EB9635DEBBF50590D506FE7937343_1317276292184_861.pdf
here is the change to the relevant law:
Law 42.15 – Bowler attempting to run out non-striker before delivery
law 42.15 shall be replaced by the following:
the bowler is permitted, before releasing the ball and provided he
has not completed his usual delivery swing, to attempt to run out the
non-striker. Whether the attempt is successful or not, the ball shall not
count as one of the over. if the bowler fails in an attempt to run out the
non-striker, the umpire shall call and signal dead ball as soon possible.
sgcricket
« Reply #17 on: February 22, 2012, 07:35:34 AM »
in cricket there are Laws - not rules.
you have both in cricket. there are the laws as per MCC. then you have rules for the different tournaments. as in, you can make some changes to a particular rule. for e.g. not allowing mankading could be a league rule that you set.
« Reply #18 on: February 22, 2012, 07:40:07 AM »
Let's get one thing clear. Those are not the laws of cricket as maintained by the mcc. Those are the icc playing conditions which the icc lays down for odi games. More to the point, odi rule 42.15 says the same as law 38.2b.
sgcricket
« Reply #19 on: February 22, 2012, 04:48:35 PM »
i really don't understand where it says that the ball must touch a fielder before the wicket is put down. could you care to enlighten me on that?
« Reply #20 on: February 22, 2012, 06:14:53 PM »
38.2. Batsman not Run out
Notwithstanding 1 above, a batman is not out Run out if
(a) he has been within his ground and has subsequently left it to avoid injury, when the wicket is put down.
Note also the provisions of Law 29.1(b) (When out of his ground)
(b) the ball has not subsequently been touched by a fielder, after the bowler has entered his delivery stride, before the wicket is put down.
FvanN
« Reply #21 on: February 22, 2012, 08:44:22 PM »
I have got to try this in a game........
