Author Topic: Removing sticker residue  (Read 9638 times)
trypewriter
Re: Removing sticker residue
« Reply #15 on: May 30, 2012, 04:42:51 PM »
nail varnish remover can work on some glues.
Richard @ CricTech
« Reply #16 on: May 30, 2012, 06:42:27 PM »
you can use a small amount of olive/veg oil on the glue. it will lift it straight off, then wipe and sand down to remove any traces of oil
« Last Edit: May 30, 2012, 06:44:34 PM by Richard @ CricTech »
SkipperJ
« Reply #17 on: June 01, 2012, 09:26:49 PM »
Option 1 (preferred) - Dab some white spirit (mineral spirit) on a rag and wipe off the glue (sometimes needs a bit of rubbing with the soaked rag). Nail polish remover works similarly, but might not be strong enough for residue from really old stickers / facing.
Option 2 (If the bat is dry and you usually oil the face) - Apply some linseed oil to the face, lay the bat down flat for a while (10-15 mins). The oil weakens the glue's bond. Then scrape off the mess with a straight blunt edge (like the edge of a plastic giftcard or an old credit card)
CBF gave me BAD real bad!
