Author Topic: How to fix this  (Read 3348 times)
Colesy
How to fix this
« on: May 08, 2012, 05:53:54 PM »
Bulldog Cricket
  • Trade Count: (+31)
    • Bulldog Cricket
Re: How to fix this
« Reply #1 on: May 08, 2012, 06:29:22 PM »
Glue and pin joe. I can do it for you if you like.
Colesy
Re: How to fix this
« Reply #2 on: May 08, 2012, 06:37:21 PM »
It's not my bat but I said I would put pictures up on here for the best course of action. If it was simple I would do it myself but if the consensus is it needs professional work then I'll let the owner know
Re: How to fix this
« Reply #3 on: May 08, 2012, 06:42:20 PM »
Adams?
Colesy
Re: How to fix this
« Reply #4 on: May 08, 2012, 07:00:56 PM »
Correct
hit4six
  • Trade Count: (+35)
Re: How to fix this
« Reply #5 on: May 08, 2012, 07:10:04 PM »
Pretty much echoing what has been said previously, but the way I would repair this would be:
- Over the damaged area in glue, ensuring plenty has seeped into the visable crack.
- Using a g-clamp, lightly clamp the area (approximately 75% closed)
- Using a vice (if available), clamp the bat together to ensure the repair is 'straight'
- Completely close the crack by securing the G-Clamp.
- Using 6mm hardwood dowel, insert 2 -3 sections for extra strength
- A layer of bat tape and a scuff sheet to finish!
Colesy
Re: How to fix this
« Reply #6 on: May 08, 2012, 09:53:57 PM »
Thanks Craig and Kieron. Gonna get hold of a G clamp and give it a go (except dowelling) and see how we get on.
Colesy
Re: How to fix this
« Reply #7 on: May 18, 2012, 11:20:37 AM »
Well here's my attempt at fixing it. Still need to apply tape which I'll do later tonight.
Ryan
  • Trade Count: (+17)
Re: How to fix this
« Reply #8 on: May 18, 2012, 11:26:53 AM »
looks good mate, just get a little tape round it and bobs your uncle!
Colesy
Re: How to fix this
« Reply #9 on: May 18, 2012, 11:28:33 AM »
Thank mate. Seeing as it will be just a net bat I think it's a decent enough fix haha, especially as I'm not the most gifted when it comes to craftsmanship
Ryan
Re: How to fix this
« Reply #10 on: May 18, 2012, 11:32:24 AM »
honestly youve done a good job there mate, i did one a month back and its still going strong! he's using his as a match bat and scored about 150 odd runs with it so far.
Talisman
  • Trade Count: (+76)
Re: How to fix this
« Reply #11 on: May 18, 2012, 11:32:47 AM »
Sorry I didn't see this first time out but you've done the right thing by not dowelling it, it didn't need it and you've done a top job by the looks of it.
Colesy
Re: How to fix this
« Reply #12 on: May 18, 2012, 11:37:00 AM »
Thanks Mike, never dowelled something before so didn't really want to risk it with someone else's bat. Hoping that it will hold together and I won't have to do it again in a few weeks lol
Number4
Re: How to fix this
« Reply #13 on: May 18, 2012, 11:39:04 AM »
What sort of split would need dowelling? Something running up the bat and split through maybe?
Talisman
Re: How to fix this
« Reply #14 on: May 18, 2012, 11:41:11 AM »
Well your bat had lift, rather than split so the dowell is purely a re enforcement which would be needed with a split but would not aid a lift. It would also deaden the area and so you often only see them in the toe in pairs as this adds stength whilst not ruining a playing area, the dead spot from dowells goes across the centre on the blade from the edge.
