Author Topic: Batting - something to think about...  (Read 6170 times)
« on: May 09, 2012, 06:59:08 AM »
In my opinion there are very few cricket writers around who are as good as "the Old Batsman", this week he has written a piece on Shane Watson http://theoldbatsman.blogspot.co.uk/2012/05/shane-watson-against-nature.html
however, take Shane Watson's name and think about your batting instead - I think you will find the main part of the commentary might give you pause for thought...
Shane Watson: Against Nature
Few batsmen fail as rarely as Shane Watson. Unfortunately for him, few batsmen succeed as rarely as Shane Watson, either. Here are his consecutive Test innings from July to December 2009: 62, 53, 51, 34, 40, 0, 96, 48, 89, 30, 93; and from October 2010 to September 2011: 56, 57, 32, 36, 41, 51, 57, 13, 95, 5, 54, 45, 38, 22, 0, 36. They are arbitrarily selected, but they represent nearly half of his career, and reflect his almost morbid consistency.
If you were to imagine average as a horizontal line on a graph with each innings marked as a dot either above or below that line, great players would produce something like the cardiograph you get in soap operas as a lead character lies liminally between life and death, with its peaks and with its valleys. Shane's would look more like the moment that the patient flat-lines and the doctors rush in to close the curtains, usher out the mistress and fire up the defibrillator.
Watson is an Australian straight off the drawing board. He presents such a convincing physical embodiment of their sunny idyll that the selectors seem to be investing in the inevitability of his success. You don't need Moneyball or the Availability Heuristic to think that if Shane Watson looked like Simon Katich, he might not have had the same opportunities. In the great certainty that his batting produces lies the uncertainty over him and his team.
He opened the batting in all of the innings listed above, something he has done 45 times out of the 64 occasions he has gone to the crease for Australia. A further six have come at his new position at number three, where, along with David Warner and Ed Cowan, he completes a trio of batsmen far less convincing than the three that follow.
It might not be fair to compare him to Ponting, who he periodically enjoys running out, or Dravid or Lara or Sanga, but it's worth looking at players of the same generation as him who fill that spot. Jonathan Trott has batted 48 times for England, making seven hundreds and nine fifties. Hashim Amla has gone in 103 times for South Africa, and made 14 hundreds and 23 fifties. Multiplied out, Trott is making scores at roughly the same rate and weight as Amla. Watson, who falls between the two in terms of experience, has batted 64 times, making two hundreds and 18 fifties. Trott's centuries include two doubles, a 184 and a 168. Amla has a highest score of 253, and four others above 140. Watto's best is 126. He has one less Test ton than Ravi Bopara.
It's against the nature and the history of batsmanship to be out for a median score as often as Shane is. Ultimately the greatest quality in batting is to be able to stay in, because everything else springs from that. Why can't he do it? Well, that might be asking to know something of his psyche or his soul. From the outside, he seems to be a momentum player, internal rhythms attuned to constant motion, disrupted when the flow is dried by the inevitable raising of defences by the bowling side as the game moves on.
Hashim Amla has made 52 per cent of his Test runs in boundaries and sixes. Jonathan Trott has made 44 per cent of his that way, Alastair Cook 46 per cent, Ricky Ponting 48 per cent, Kevin Pietersen 54 per cent. Watson has a percentage above all of them at 57. Only freaks like Sehwag with 67 per cent and Chris Gayle with 75 per cent go beyond him, and they each have two triple centuries in Test cricket. The stats suggest two things about the way Watson plays: that he needs boundaries to build his score, and that he gets out trying to hit them once the field goes back. Both are symptomatic of a player who either doesn't look at where the field is, or who can't keep hitting the gaps. That's guesswork, though. Perhaps Shane is just a rebours.
Dan W
Re: Batting - something to think about...
« Reply #1 on: May 09, 2012, 07:07:38 AM »
Rebours?!
« Reply #2 on: May 09, 2012, 07:22:20 AM »
the expression is "a rebours" and it is French for "doing it a different way" or a bit like the word "doosra" which means "the other way"
dhackett89
« Reply #3 on: May 09, 2012, 07:24:18 AM »
i can see the point but it all seems a bit harsh on him, hes a pretty fine playe. also ignores the fact he averages around 30 with the ball and has made six odi hundred one of which was about 180, abeit against bangladesh. in some ways id take his consistancy over a big score or nothing man, particuarly when hes followed by Ponting, Clarke and Hussey who make hundreds but fail reguarly (more so ponting and hussey) at least watson always gives a stable base. interesting piece tho
Manormanic
« Reply #4 on: May 09, 2012, 07:28:08 AM »
I think its a very well written piece and makes a point a lot of others have made about Watto.  I don't think its fair to dismiss the guy for being consistently average, but I wonder if thee Aussies would have settled for the same from someone a decade ago.
« Reply #5 on: May 09, 2012, 07:35:20 AM »
And how true is this in Club Cricket?
langer17
« Reply #6 on: May 09, 2012, 07:37:31 AM »
He is an all-rounder who opens the batting but doesn't bowl much because it puts a strain on him to open and his body is already injury plagued. His best place is opening, but in order for him to bowl more, he needs to bat down the order. He is a good bowler, but he wouldn't be in the team for his bowling, even though he has a handy 59 wickets at 28.91, which is very respectable. This leave him in the team as a batsmen only and they should bowl him for a few overs here and there.
He just cannot do both, either bat down the order and bowl more - Chances are he'll get a solid amount of time to bat with how Australia have been crumbling with their batting at times, or, leave him as an opener and give him small spells in bowling (which is kind of pointless really).
« Last Edit: May 09, 2012, 07:42:00 AM by langer17 »
« Reply #7 on: May 09, 2012, 07:41:40 AM »
that is the point, how many club players struggle when the boundaries are dried up...
Canners
  • go hard or go home
« Reply #8 on: May 09, 2012, 08:04:19 AM »
i think the way he's out could tell us more, buzz in sure you have his stats in that head of yours somewhere :)
Simmy
« Reply #9 on: May 09, 2012, 08:11:08 AM »
me  :(
Manormanic
« Reply #10 on: May 09, 2012, 08:11:48 AM »
Is it really?  I'd have said that he goes too hard at the ball to be a successful opener...
A-Swing-And-A-Miss
« Reply #11 on: May 09, 2012, 08:23:17 AM »
Would prefer to have someone like Watson who consistently scores 30+ runs an innings as opposed to someone like Cook who will get 5-6 scores of under 10 then a big double hundred.
Tumo
« Reply #12 on: May 09, 2012, 08:28:52 AM »
Well Cook used to be like Watson, scoring 40-70 a large percentage of the time, and then get out, and people knocked him for it! Can't have everything...
Manormanic
« Reply #13 on: May 09, 2012, 08:35:56 AM »
Not really - Cook has patches of that form but is at least reliable when he does get in.  Someone like Watson could probably be hidden in a stronger top order but alongside teh hit and miss Warner and Cowan who...much as I like the guy, doesn't seem to be quite test class...leads to unnecessary exposure for the middle order.
« Reply #14 on: May 09, 2012, 08:37:00 AM »
http://stats.espncricinfo.com/ci/engine/player/8180.html?class=1;template=results;type=batting;view=dismissal_summary
For Canners.
Interesting that of all the run outs Watson has been involved in, he has only been the victim twice...
