Gunn and Moore Icon DXM Original L.E.
Author Topic: Gunn and Moore Icon DXM Original L.E.  (Read 3333 times)
littlemaster
« on: May 30, 2012, 03:57:45 PM »
I got one of these bats for my birthday last year and it snapped in August, I then got it repaired and GM sent it back. It has now fully snapped down the middle. I have previously had 4 GM's that have done the same. What is wrong with GM??
Jagminder
Re: Gunn and Moore Icon DXM Original L.E.
« Reply #1 on: May 30, 2012, 04:05:14 PM »
Are you using good quality balls?
How do you store your bats during winter?
If it has happened to your bats so many times - it can't be just bad luck.
Jag.
littlemaster
« Reply #2 on: May 30, 2012, 04:08:29 PM »
I am mainly using Dukes balls around £4 and they don't wear out easily. I store my bat in my cricket bag which lives under my bed most of the time.
A-Swing-And-A-Miss
« Reply #3 on: May 30, 2012, 04:15:49 PM »
Do you oil/knock them in properly. 5 bats all doing the same sounds far too many to be a coincidence tbh. Also, if you had already broke 4 GM bats why did you then decide to get a really expensive GM bat? Did you not think of moving onto another brand instead?
Perkins17
    • GM Cricket
« Reply #4 on: May 30, 2012, 04:46:54 PM »
It could be down to a fault in the willow but I would say the main problem is the fact your using £4 balls on a £300 bat which is never a clever idea!
how much knocking in did you do and did you play it in against old balls?
« Reply #5 on: May 30, 2012, 04:59:09 PM »
Quite - £4 Dukes balls are Bat Breakers, and no amount of knocking in is going to change that...
Jagminder
« Reply #6 on: May 30, 2012, 05:06:54 PM »
£4 Dukes balls are Bat Breakers...........................
This sums up I guess.
