M&H Solution
Author Topic: M&H Solution  (Read 4031 times)
WABH-J
Johnny
Re: M&H Solution
« Reply #1 on: August 17, 2012, 05:46:47 PM »
Perhaps try a custom maker on here?
Re: M&H Solution
« Reply #2 on: August 17, 2012, 05:48:03 PM »
ItsJustCricket
    • Its Just Cricket
Re: M&H Solution
« Reply #3 on: August 17, 2012, 05:58:15 PM »
M&H Original Low
https://www.mandhstore.co.uk/index.php/cricket-bats/original-low-385.html
£150
Yes, the Original Low is exactly the same shape as the Solution, but much cheaper.  M&H are apparently selling it for a bit less than we are at the moment, though!  :-[
Have it in stock in 2.10 and 2.11: http://www.itsjustcricket.co.uk/cricket-bats-c17/senior-cricket-bats-c18/millichamp-hall-original-low-cricket-bat-p348
WABH-J
Re: M&H Solution
« Reply #4 on: August 17, 2012, 06:04:42 PM »
Thanks fellas!
jimba101
Re: M&H Solution
« Reply #5 on: August 17, 2012, 06:24:29 PM »
I'd say the redback allegiance has a similar profile. Maybe worth a look...
Re: M&H Solution
« Reply #6 on: August 17, 2012, 06:33:54 PM »
IJC could be cheaper with your 10% off code ;)
ItsJustCricket
    • Its Just Cricket
Re: M&H Solution
« Reply #7 on: August 17, 2012, 06:44:04 PM »
Not sure if he has one, Steve.  Will have to check!
Re: M&H Solution
« Reply #8 on: August 17, 2012, 07:48:49 PM »
Well if he hasn't he's missed out! :D
ItsJustCricket
    • Its Just Cricket
Re: M&H Solution
« Reply #9 on: August 17, 2012, 08:15:53 PM »
You could argue that, but doesn't it make you feel more special, Steve, knowing that you are one of a select few with these elusive 10% codes?!  ;)
junter97
Re: M&H Solution
« Reply #10 on: August 17, 2012, 08:18:41 PM »
Oh it does! And it's got my name in ;) Even better!!
ItsJustCricket
    • Its Just Cricket
Re: M&H Solution
« Reply #11 on: August 17, 2012, 08:26:43 PM »
Ssshhhhh! Someone might steal it off you now!! Better get your order in quick now! ;)
BakarooBonzai
Re: M&H Solution
« Reply #12 on: August 18, 2012, 03:33:33 AM »
So there's no difference between the solution and the original low than the price?
Vantage_Cricket
Re: M&H Solution
« Reply #13 on: August 18, 2012, 09:20:00 AM »
I think there is a different in the grade of wood? Or the Solution is made with an O/S cleft or something like that.
mally777
Re: M&H Solution
« Reply #14 on: August 19, 2012, 07:57:06 PM »
Yep, the MH Solution Low is Grade 2 willow but still a good buy for £150.
