Author Topic: Bat Grips  (Read 5104 times)
acko109
Re: Bat Grips
« Reply #15 on: May 22, 2009, 11:02:20 PM »
i have a grip which is the bottom half of the shock absorba all the way up and its brilliant no movement or nothing even after a long bat and slippy palms still no movement
Conchord
Re: Bat Grips
« Reply #16 on: May 22, 2009, 11:08:23 PM »
Rubber is light as anyway. Making a grip that's really easy to put on would be good. Without having to get special appliers like the GM vacuum and the octupus thing.
goldy_boy
Re: Bat Grips
« Reply #17 on: May 28, 2009, 10:28:28 AM »
Check out a load of hot water bottles, you might find some good grips and textures on there.
That's actually a really good idea, will look into it! Keep posting as more and more ideas will only be better for you guys, since as I said I reckon I can get it put out there should you want it enough.
