Pages: 1 2 [3]
Author Topic: Weight vs Pickup  (Read 5957 times)
norbs
Re: Weight vs Pickup
« Reply #30 on: October 17, 2012, 01:02:54 PM »
Would you recommend bringing batting gloves to the workshop, as I find they sometimes alter pickup?
Some people like to try them with gloves some dont....
SkipperJ
« Reply #31 on: October 17, 2012, 01:26:51 PM »
You are only late on the shot with a heavier bat if the swing weight is out of your norm! MMOI ;)
^ This ^
CBF gave me BAD real bad!
steelcouch
« Reply #32 on: October 17, 2012, 02:09:22 PM »
Bats haave prgress a hell of a lot in shapes, size and performance, but in one area i think we shoudl look to history and that is bat selection.
In days gone by when we were less fickle i cant see peopl eregularly coming out with bats too heavy for them etc.
These days we are making ego purchases ( we have all done them!) and going after big bats and trying to justify them because " it has a great pick up"
I think this is different to exploring your optimum weight where you do need experiementation to find what works form you, but in the past you tended to go from the lightest weighing bat, that you were pretty sertain you could use to simething neavier gradually.
Tip, hold a bat in your top hand and extend you arm fully. If you can hold that with out undue effort. i.e. no movement whatsoe ever for ten seconds then you bat is not too heavy for you.
You will be able under normal cirecumastances pklay all shots and have enough strength to play an innings.
All this optimum stroke speed etc will have limited effect if you do not have the FITNESS AND STRENGTH to use your bat.
Fatigue has a massive effect on skil. That is something they do not teach you in Pysics books i am afraid.
1) get the right weight of bat for you  ( i agree an ounce or so shoyudl not have too much effect. 2 oz i think is a significent step up, but managable i.e a nicely weighted heavier bat compared to a badly weighted light bat)
2) get set up right. middle, pick up edges
3) DOnt change, unless given EXTREMELY good advise to the contry. Remember most of people have strong opinions on cricket. 80% are incorrect.
Only listen to proven experts if not in supply, then trust yourself.
4) I dont begrudge peopl espending money on things they like, or even love. Hell i have a room full of sports equipment, but i would guess that over 50% of peopl eon here use bats too heavy to encourage all round stroke play. It is only the last 40 years where professional were using more than 2lb 6 and they were still hitting sixes.
« Last Edit: October 17, 2012, 07:45:49 PM by steelcouch »
SkipperJ
« Reply #33 on: October 17, 2012, 04:21:11 PM »
Tip, hold a bat in your top hand and extend you arm fully. If you can hold that with out undue effort. i.e. no movement whatsoe ever then you bat is not too heavy for you.
Agree with the above. The other tip for selecting a bat - hold it with only your top hand, and swing it through a few times, making an arc mimicking your back lift and a shoulder-high followthrough. You will know which bat feels right.
Also, even if you get a bat that is 1-2 oz heavier, work on your fitness (pump those weights!) You will see better returns, compared to searching for the holy grail.
Lastly, the best judge of what is right for you is *YOU*. If you pickup a bat and it feels perfect in your hands (regardless of actual dead weight) go for it - like the OP.
trypewriter
« Reply #34 on: October 17, 2012, 04:27:43 PM »
One useful thing that I was told - buy a guy selling bats, so he was keen for buyers to get it right - was to follow the above advice, but to try to stop the swing at various points. The theory being that if you couldn't stop the swing comfortably, the bat was too heavy for you to control.
« Reply #35 on: October 17, 2012, 05:17:51 PM »
there are some really good thoguhts on this thread - loving the idea of swinging the bat around like a madman and trying to stop, whilst retaining control...
some of the old school tips like the arm outstretched ones are the best.
With a slightly heavier bat, once you have hit a few boundaries with it, your confidence can go up with the bat and you can cope just fine.
Except on a really hot day when you are sweating buckets in your lid and your lack of fitness shows you up...
Pages: 1 2 [3]
