Pages: 1 [2] 3
Author Topic: rubber vs cork?  (Read 13432 times)
Re: rubber vs cork?
« Reply #15 on: February 12, 2013, 09:26:22 PM »
Weight is the simple answer
how much weight saving are we talking about?
Canners
  • go hard or go home
Re: rubber vs cork?
« Reply #16 on: February 12, 2013, 09:26:55 PM »
from what i hear there can be a difference of at least an ounce in weight, there by given bigger bats at a lighter weight
Re: rubber vs cork?
« Reply #17 on: February 12, 2013, 09:42:51 PM »
The KG I came across had cork and it was dreadful! Detested it!!
My SS has rubber.
When I got CA bats made I asked Zahid Javed why they don't use rubber and he as Matt said it adds weight and there isn't much of a difference anyways.
Personally I prefer rubber as it makes pickup better IMHO which does make sense as more mass in hands.
Ryan
  • Trade Count: (+17)
Re: rubber vs cork?
« Reply #18 on: February 12, 2013, 09:52:38 PM »
I think the best combo is cork/ rubber/ cork.  The cork sticks better than rubber so its used in the ends.
Re: rubber vs cork?
« Reply #19 on: February 12, 2013, 10:26:42 PM »
My B3 is cork and i can't tell the difference!
Re: rubber vs cork?
« Reply #20 on: February 13, 2013, 01:16:14 AM »
Never paid attention to this, so if i get it right cork inserts essentially replauce the dark rubber inserts/lines in your bat handle? would that be the only way to tell? can someone post pics..i am not sure i would have noticed...
Re: rubber vs cork?
« Reply #21 on: February 13, 2013, 01:20:17 AM »
Sure, I'll get some pics up, give me a few minutes. 8)
Re: rubber vs cork?
« Reply #22 on: February 13, 2013, 02:35:01 AM »
Cork inserts:
MSR
CA Plus 5000
And rubber inserts:
Broken Fusion bat (Unsure if UK or Asian made...)
Red Ink LE
Hunts County Triumph Cyclone
Helios Atlas
Hybrid Handles:
Laver and Wood PB with C-ten handle (Has cork inserts)
Pakistani made Plain bat - cork-rubber-cork handle (An absolute gun according to friend I bought it for)
I didn't actually realise that rubber inserts came in different colours until I looked at my Helios' handle a little while back! Generally speaking, if you dig your nail slightly into the insert, you will find that rubber ones are slightly 'bouncy' while cork tend to be harder.
The fact that the C-ten handle has cork inserts suggests to me that cork inserts may perhaps give a slightly stiffer handle than rubber inserts, but I could be very wrong. They may be used instead of rubber as cork is lighter, or maybe even because the handle just constructs better with cork! A question for JL himself I reckon!
One thing I don't know how people figure out is the 'piece' number, like a 12 piece cane handle, how do you tell? From a glance, I can't really tell at all, I would call all of the handles I have popped up 4 piece cane handles, but I am not sure. What does the number of pieces do to a handle anyways? :-[
Re: rubber vs cork?
« Reply #23 on: February 13, 2013, 05:28:58 AM »
Its not visible as top is sanded, buffed etc so the joints are difficult to see.
However, here is a picture which I found. Not very comprehensive but should give you an idea;
I think pieces add strength to the handle, greater the number of pieces stronger it will be (and more energy absorption) and vice versa.
jamesisapayne
Re: rubber vs cork?
« Reply #24 on: February 13, 2013, 10:48:56 AM »
I always thought they were solid pieces Uzair!
Now I know ;-)
Re: rubber vs cork?
« Reply #25 on: February 13, 2013, 12:00:50 PM »
Thanks Chad and Uzair
IQ
Re: rubber vs cork?
« Reply #26 on: February 13, 2013, 12:12:09 PM »
One thing I have seen, the Pak made bat handles have a lot of black "burn" marks.
What are those? (Hope some one knows what I am talking about!)
Re: rubber vs cork?
« Reply #27 on: February 13, 2013, 01:01:48 PM »
I believe a 12 piece handle is supposed to be stiffer than a 4 piece handle.
Fezballoh
Re: rubber vs cork?
« Reply #28 on: February 13, 2013, 06:37:46 PM »
Could be where they are turned on the lathe that the operator is using a blunt chisel when he's turning them out. Someone posted a lovely video of a bat factory on here somewhere and you can see the guy turning square handles into round ones (you've gotta be real careful doing that belive me!) Ryan, are you making your own handles on your lathe? I might have a go if i can source some cane.
Ryan
Re: rubber vs cork?
« Reply #29 on: February 14, 2013, 01:00:30 PM »
Not yet, I'd like to give it a go but its hard to find them "unturned". Be good if i could as I'd prefer them to be a bigger oval so I'm not constrained on the size.
Pages: 1 [2] 3
