Pages: 1 ... 4 5 [6] 7 8 ... 16
Author Topic: Bat Grip Database  (Read 210896 times)
smokem
Re: Bat Grip Database
« Reply #75 on: February 08, 2013, 09:39:51 AM »
Were these the same as that were on the Kookaburra Blade runner? They sat nicely in the hand.
I haven't tried the Kooks. For the grip that I did manage to put on, it squirms around in the hand which I find a bit disconcerting. Also bits tear off from the ribs quite quickly...
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #76 on: February 18, 2013, 11:25:09 AM »
These are definitely my favourite kind of bat grip, salix hybrid style.
« Reply #77 on: February 18, 2013, 03:28:07 PM »
just swapped a couple of my bats to this type of grip this afternoon to see what they are like, only marginally heavier than a normal chevron and alot lighter than a spiral.
swamidude
« Reply #78 on: February 18, 2013, 06:43:29 PM »
What style of grip is the bottom half of the Salix hybrid grip? It looks slightly different to a spiral.
vibrate
« Reply #79 on: March 10, 2013, 06:02:06 AM »
Im guessing ebay is the best place to buy some grips?
« Reply #80 on: March 10, 2013, 07:15:53 AM »
try the forum sponsors. they have loads!
Blazer
  • Team Anti - Concave !.
« Reply #81 on: March 10, 2013, 08:15:25 AM »
Bulldog cricket and Ryan Fletcheruk sell some lovely UK made grips.
RoCo Da Pixie
« Reply #82 on: March 21, 2013, 09:58:04 AM »
I need to bulk up the bottom hand on my Salix bat, The oval handle isn't as large as I would generally like it. So what suggestions do people have?
« Reply #83 on: March 21, 2013, 10:20:53 AM »
Half a grip??
ProWannabe88
« Reply #84 on: March 21, 2013, 10:28:19 AM »
Would this aid bottom hand control?? I have a bit of a problem with my bottom hand taking over my top hand. Only when I'm defending. Driving etc is all ok because I'm going at the ball. In defence I close the face. Not a lot but would half a grip under my normal set uo aid the issue??
RoCo Da Pixie
« Reply #85 on: March 21, 2013, 10:30:25 AM »
I would think half a grip. But it was more of a census to see what others use. As in half a spiral, Chevron etc.
« Reply #86 on: March 22, 2013, 04:12:29 PM »
Can't quote today
"I would think half a grip. But it was more of a census to see what others use. As in half a spiral, Chevron etc. "
Anyone ever weigh their grips? during the excercise of weighing my bats I ended up thowing some grips on the scale to see what the weight was and found...
Chevron (Most H4L have this white Chevron on): 61gm
Salix Hybrid: 43gm
Salix Spiral: 47 gm
So if you are adding grips to make handle thicker as the bottom and weight is a consideration I would almost suggest cutting a spiral in half and hybrid on top...will weigh the rest later tonight and I have a few different kinds
El Nino
« Reply #87 on: May 08, 2013, 03:58:45 AM »
Anyone with any thoughts on these kook grips? always used octopus but these look the goods?
good/bad reviews?
morgzy10
  • Amateur Kit Badger
« Reply #88 on: May 08, 2013, 08:41:14 AM »
nino, look back through this thread, youll see the views,  i had one on my old kooka blade and the grip was an absolut train wreck, it got worn and sticky and just went all over the shop,    after two uses!
www.twitter.com/sj_morgs10
HS= 164*  Best Bowling = 6-19
El Nino
« Reply #89 on: May 08, 2013, 09:42:00 AM »
Yeah, was only reviews on other ones similar was hoping the Kook ones might've been a bit better quality. No worries thanks for that I'll steer clear!
