Pages: 1 [2] 3
Author Topic: Lavers "mongoose"  (Read 11002 times)
SAF Bats
    • San Andreas Fault
Re: Lavers "mongoose"
« Reply #15 on: June 01, 2009, 09:09:43 AM »
Nope Matt.... I just used the conventional method
Email: cricket@safbats.co.uk
Liam-SCCC
« Reply #16 on: June 01, 2009, 10:17:05 AM »
please could we have pictures Norbair?
Top Score: 102*
Best Bowling: 7/29
SillyShilly
« Reply #17 on: June 01, 2009, 10:43:03 AM »
Am i right in thinking that it is possible to get two bats out of a single cleft with the 20/20 bats yet still charge astronomically high prices........i am suprised they didn't think of this earlier!!!
i am very much a skeptic of this new bit of 'technology' - Norb, have you followed a similar design to the mongoose and laver, or have you added your own special twist?
SAF Bats
    • San Andreas Fault
« Reply #18 on: June 01, 2009, 10:49:51 AM »
I'll measue a cleft when I go and take some pics and let you know
Tom
    • www.cricketinsight.co.uk
« Reply #19 on: June 01, 2009, 10:55:26 AM »
I'm pretty sure you can't, although you could get cheaper clefts which maybe had knots at one end or chunks out of them. Or even order shorter clefts.
SAF Bats
    • San Andreas Fault
« Reply #20 on: June 01, 2009, 10:56:42 AM »
I dont think so either as I made a 19inch one
SillyShilly
« Reply #21 on: June 01, 2009, 11:09:48 AM »
fair enough, i stand corrected! But i still believe this is an expensive gimmick - having said that, if i went out and scored 50 or 100 with it i am sure my opinion will change, it will be interesting to see what type of feedback these bats get when they have been used a little more extensively in the professional and amateur ranks.......let us know how you get on with it at the nets!
SAF Bats
    • San Andreas Fault
« Reply #22 on: June 01, 2009, 12:41:45 PM »
Not the best quality pics
« Last Edit: June 01, 2009, 02:43:20 PM by Norbair »
Howzat
« Reply #23 on: June 01, 2009, 02:45:17 PM »
I thought the idea was it was meant to have a long handle?
SAF Bats
    • San Andreas Fault
« Reply #24 on: June 01, 2009, 02:55:28 PM »
? Total Blade length is 19inches
edit: I think I know what you are saying.... It is a normally spliced bat but edges taken away so the handle is thicker because of that...
« Last Edit: June 01, 2009, 03:47:04 PM by Norbair »
Singo
« Reply #25 on: June 01, 2009, 04:17:20 PM »
Norbair what bat is that? did you make it? do you make saf bats?
Howzat
« Reply #26 on: June 01, 2009, 04:20:48 PM »
Its Nobby 20/20 bat, yes he did and yes he does.
SAF Bats
    • San Andreas Fault
« Reply #27 on: June 01, 2009, 04:21:39 PM »
It is a normal mens handled cleft shaped into a prototype mongoose copy I did on saturday morning as I wanted to see what it was like! And yep I make San Andreas Fault bats...
Singo
« Reply #28 on: June 01, 2009, 04:25:56 PM »
Do you think the bat is as powerful as it says on the tin ;) is it worth buying? Played with it yet?
SAF Bats
    • San Andreas Fault
« Reply #29 on: June 01, 2009, 04:29:39 PM »
Not yet I'm using it tonight in nets.... Thing is mine is different because it is spliced conventionally therefore the wider handle area at the shoulder... If I've still got a handle in the bat after nets tonight [:D] I'll let you know... As I'd imagine everyone is going to want to have a go.
Pages: 1 [2] 3
