Pages: 1 2 3 [4] 5 6 ... 11
Author Topic: larry the lam-inate, take two!  (Read 25704 times)
Re: larry the lam-inate, take two!
« Reply #45 on: November 17, 2012, 06:41:39 PM »
i'll provide a 3lb 6 plank for you to cork and laminate as an experiment ..... if you are up for it
« Reply #46 on: November 17, 2012, 06:43:38 PM »
would have to be paper thin.. but im not sure tk has any sort of actuall rubber in there id think it was all just glue based rubber stuff
I have seen a few Keeley bro laminates with rubber inserts and yes the cut off was only a quarter of the face but it hate a rubber type sheet in there
Ryan
  • Trade Count: (+17)
« Reply #47 on: November 17, 2012, 06:53:34 PM »
I've got some regupol which is acoustic matting made from cork and rubber but I think it's a little thick. I'll make some enquiries and find a thinner alternative.
« Reply #48 on: November 17, 2012, 06:54:24 PM »
wow a Bro laminate... are they for players in the hood?
« Reply #49 on: November 17, 2012, 06:58:13 PM »
The ones I have seen have been scooped out types with the edges left intact and the face cut out was a very thin vanieer with the rubber inserted with a little wood removed then face well section reglueed then a scuff put over.
That way the only joines were on the face and not on the edges at all
Sorry buzz I was referring to the Keeley brothers
« Reply #50 on: November 17, 2012, 06:58:40 PM »
drink a few bottles of wine and inset the corks in a honeycomb style .... good or bad idea?
Ryan
« Reply #51 on: November 17, 2012, 07:01:03 PM »
Only thing with that is you'd have to use a router to hollow the middle out which is a little more time consuming as you'd also have to make a jig for it. Think the different types of glue would be a better idea.
Canners
  • go hard or go home
« Reply #52 on: November 17, 2012, 07:08:58 PM »
the top lams i have seen, the grains on the face of the bat dont match the grains on the back.....
Ryan
« Reply #53 on: November 17, 2012, 07:24:43 PM »
Massive!!
Blazer
  • Team Anti - Concave !.
« Reply #54 on: November 17, 2012, 07:56:08 PM »
Would a laminate play better if the thin pressed face was laminated onto a unpressed bat rather than a pressed bat/ cleft ?.
Village Trundler
« Reply #55 on: November 17, 2012, 08:35:46 PM »
Great stuff! Cant wait to see the results!
Ryan
« Reply #56 on: November 17, 2012, 08:37:05 PM »
Not sure, I would have thought pressing a bat actually actually compresses the top 5mm of a blade anyway. So if that's the case then I'd say it wouldn't make any difference.
Ryan
« Reply #57 on: November 19, 2012, 11:27:15 AM »
Just an update on "Larry", he's had his rubber bands removed and handle glued and set.  The glue should have gone off so I'll be able to finish him tonight.
Pictures to follow...
Simmy
« Reply #58 on: November 19, 2012, 11:31:44 AM »
sweeeeeeeeeet
« Reply #59 on: November 19, 2012, 12:16:38 PM »
Good work Dr Frankenstein
