Author Topic: Binding the handle  (Read 13249 times)
Re: Binding the handle
« Reply #15 on: November 20, 2012, 02:49:52 PM »
Cheers guys.  I take it wolfcraft don't make them anymore, as it's not on their website?
no its a discontinued line. shame as its a good product. keep your eye on ebay. sure one will turn up on there.
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #16 on: November 20, 2012, 02:51:59 PM »
Will do.  There's nothing there at the minute.  Not sure that I want to buy a cheapish lathe, as I'd only use it for binding.  I guees I could always try and knock something up...
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #17 on: November 20, 2012, 03:59:35 PM »
I had a thought while I was on my lunch break.  As I already have a bench mount for my drill, would it be worth getting 2 lathe centres, 1 for the drill, and 1 to put through a post fixed at the other end of the workbench, so that they are both at the same height?
« Reply #18 on: November 20, 2012, 04:06:18 PM »
yeah that can be done. you would need a lathe centre and a lathe drive to make it work but they should be available on ebay
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #19 on: November 20, 2012, 04:11:34 PM »
Put the drive in the drill and centre on the post?
« Reply #20 on: November 20, 2012, 04:17:38 PM »
yeah. you will have to get a drive small enough to fit in the chuck of the drill
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #21 on: November 20, 2012, 04:33:06 PM »
Would I need to get one of the fancy multi-pronged type centres, or jut one with a single point?  I should imagine the ones with prongs would hold better, but leave more of a mark in the wood?
« Reply #22 on: November 20, 2012, 04:35:57 PM »
you need one of each. the centre point wont drive anything. if you were just hand spining it, it would rotate on that point. in order to machine drive via a motor or a drill you will need a centre drive which grips into the wood and enables the drill to turn it. i use the drive in the end of the handle so it doesnt affect anything if it does cause any marks.
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #23 on: November 20, 2012, 04:37:35 PM »
OK.  Think I get it now.  Will have to have a look around and see what I can put together!
