Pages: 1 2 3 [4] 5 6
Author Topic: Sticker and Scuff Sheet Removal - A concise guide  (Read 146917 times)
Re: Sticker and Scuff Sheet Removal - A concise guide
« Reply #45 on: December 15, 2014, 10:44:27 PM »
will using the blow dryer minimize chances of wood coming off with the sheet?
Yes but the real key to minimizing  damage to the face is to gently remove the sheet horizontally not vertically apologises if you are aware of this.
« Reply #46 on: February 17, 2015, 05:25:14 PM »
one of my bats is making a slightly hollow sound towards the bottom of the stickers. I cannot see any cracking in the stickers that would indicate splitting. What I would like to do is lift the sticker, have a look, repair if necessary and re-glue the stickers back down.
the question is what glue can I use to re-glue the stickers.
I don't want to send it to a bat maker as I want to keep the original stickers.
« Reply #47 on: February 17, 2015, 05:34:42 PM »
Pritt stick or PVA will do the trick mate
KIPPERS
« Reply #48 on: February 18, 2015, 09:15:52 AM »
Couple of points to address. Whits spirit will not damage your bat which seems to be a concern. Its used by most carpenters to clean wood because it has few impurities and evaporates quickly so it doesn't raise the grain. Fine wire wool is great for a final polish with wax, but don't use it if there are still and fine cracks or splinters on the surface as it will catch on them.
Come in 5 and left a bit
« Reply #49 on: February 18, 2015, 09:21:13 AM »
Saved me asking the very same question.
Gboots
« Reply #50 on: May 27, 2015, 03:45:49 PM »
I just purchased a GN100 scoop (new model) on eBay and stickers are crooked on front.
Are modern stickers easier to remove ? I also want to re attach after ?
calcurtis98
« Reply #51 on: May 27, 2015, 04:06:58 PM »
If they're crooked I'd be worried they're not real, but if you're happy that's all that matters.
Batting - 61 & Bowling - 6/15
Gboots
« Reply #52 on: May 27, 2015, 04:12:09 PM »
It has the scoop and looks real. It was also only $70 AUS including postage so that it is why I am not going to be an idiot and complain about it. Too much stress when the bat actually looks reasonable.
I would be happy to try and remove / reapply sticker hence the question .
It's actually a harrow and I bought it as a sentimental item as my first proper bat as a child
was a size 6 scoop
Gboots
« Reply #53 on: May 31, 2015, 02:30:54 AM »
Removed stickers using hair drier.  Found knot which explains.
Restickered
JimmyT85
« Reply #54 on: February 19, 2016, 09:36:59 AM »
This is a great thread, thank you!
I'm going to be giving my bat a service over the next week or so, so this will help immensely!
Thanks again
Currently playing for - Sony Sixers (Last Man Stands - Liverpool)
Looking to get back into weekend cricket
Chalkie
« Reply #55 on: February 06, 2017, 10:38:37 PM »
Guys, I have a nice vintage bat that has fibreglass tape over the face and it also covers the back sticker. The willow doesn't looks too bad underneath (guess it was just for protection) so started removing the tape, but it has perished so it splinters when I try to remove it, leaving quite a lot of residue.
I will probably use a blade plus white spirit on the face, but the question is how do I clean it off the sticker without damaging it, will Sticky stuff remover/De-solv-it work without taking the sticker off as well?
Thanks,
Chalkie
« Reply #56 on: February 07, 2017, 09:06:56 PM »
@Seniorplayer  and @wayward_hayward
Guys, please see my post above, any help would be great. Thanks
tom line
« Reply #57 on: February 07, 2017, 09:09:02 PM »
@Chalkie personally for the tape over the stickers, pull the tape off to get the most off as you can, it shouldn't pull the stickers up, then you are likely to have the fibre left over. I'd use nail polish remover pads to rub this off and it should leave the stickers clean
Chalkie
« Reply #58 on: February 07, 2017, 09:53:42 PM »
Cheers tom, will wait till my wife is out then raid her makeup cupboard so I can give that a go
« Reply #59 on: February 08, 2017, 08:16:19 AM »
If you want to avoid an angry wife just buy a tub of Acetone from your local hardwear store, it's a lot cheaper than nail polish remover, though she might figure that out and start stealing it!
