Author Topic: Why you should knock in the middle of your bat as well  (Read 4987 times)
« on: February 12, 2013, 11:06:59 AM »
Plenty of advice on this forum about doing toes/edges and leaving the middle. Well here's an example of what can happen when you don't do huge amounts of knocking in to the middle:-
Now this bat has been knocked in for 4 hours+, netted with a few times, given some more knocking in. Batbreaker ball?, possibly but the edges are still intact. It's not the end of the world, I'll stick some fibre tape over the area and send it back to Matt for a refurb in the autumn. Still, make sure you give all the bat a good knocking in.
Dan W
Re: Why you should knock in the middle of your bat as well
« Reply #1 on: February 12, 2013, 11:17:47 AM »
We've all been there, I feel your pain!
I'd wager the culprit is a bat-breaker tho it's one of the worst sights in the world on your new baby!
Simmy
« Reply #2 on: February 12, 2013, 11:20:20 AM »
never happened to me that and i never really do it?
must have been a rock hard ball
Number4
« Reply #3 on: February 12, 2013, 11:23:05 AM »
That's cause you don't hit the ball in the middle  ;)
Simmy
« Reply #4 on: February 12, 2013, 11:27:17 AM »
ha ask vitas cricket ;)
« Reply #5 on: February 12, 2013, 11:29:32 AM »
I had a hattori that was fully knocked in and this happened because they were using a bat breaker. I told them if they insisted on using it I was going to walk off. So they changed it, this was in a game as well!
fasteddie
  • Straight up.
« Reply #6 on: February 12, 2013, 11:29:59 AM »
Forgive my simple question.
As there are only 4 grains, does that not indicate itself a potentially softer blade?
That must have been a pretty solid ball to do that.
« Reply #7 on: February 12, 2013, 11:36:58 AM »
It happened Sunday but against the slowest bowling I've ever faced. The attack at one point consisted of three 60 year olds bowling donkey drops, I questioned whether there was even a point to facing it! I'm not totally convinced they could put enough pace on the ball even with a bat breaker.
« Last Edit: February 12, 2013, 12:53:40 PM by uknsaunders »
ppccopener
« Reply #8 on: February 12, 2013, 11:41:48 AM »
it's gone along the grain a bit,sometimes happens if it's a bit soft pressed.i try to have soft pressed bats myself as what you gain in 'ping' is worth it.
ive had exactly the same happen in nets and confiscated a few conkers recently
the wood is very pale and normally that's a good sign of grade 1.
hammer the area with a bat mallet around it and you might find it blends in a bit
hurts thou to damage your pride and joy in the nets I know.....
looks like a quality willow thou to me...
fasteddie
  • Straight up.
« Reply #9 on: February 12, 2013, 11:48:26 AM »
aka 'hand-grenades'
was it the type of bowling 'Dear Geoffrey' could 'throw his hat on?'
Surface cracks are a good sign, so I've been told all these years. Hopefully you can ignore the crack and lay waste to the bowling next time!
Ryan
  • Trade Count: (+17)
« Reply #10 on: February 12, 2013, 11:51:18 AM »
I'm more shocked that you've hit one in the middle nick! haha
« Reply #11 on: February 12, 2013, 11:53:25 AM »
What have you done to my bat?!!!!!!!!!!
« Reply #12 on: February 12, 2013, 12:18:29 PM »
That's what I'm going to do and a general bit of face knocking in.
Ryan, I'm quite surprised how many look close to the middle, that said at the speed they bowled the biggest danger was falling asleep while waiting for the delivery to come down.
« Reply #13 on: February 12, 2013, 12:35:45 PM »
Just out of curiosity could it be that you knocked the bat too much? I have had a couple of bats where after hours of knocking in the middle this develops. You can hit it as hard as you like with the mallet but indentations form, all you see is this crack/fracture along the grain lines but the bat plays really well...
I have always wondered if you can achieve surface cracks that develop on a well played in bat with knocking process...There was a very hard pressed GM that did it ( 30 to 60 mins of knocking daily for 2 weeks) and also happened to my Lekka, both bats played really well...
« Reply #14 on: February 12, 2013, 01:40:55 PM »
Looks like an evil hard ball to me...!
