Pages: 1 2 [3]
Author Topic: Have at it...  (Read 6992 times)
Re: Have at it...
« Reply #30 on: March 05, 2013, 12:26:00 PM »
Can I ask why?
In match situations I really depend on my run up & rhythm but since there is only about 5 odd steps indoor i come in at a curved angle which i think gives me an extra step or two in the run up but also results in going across...most times when i run in indoors I am almost looking at fine leg...not a good habit i know...
also just to add I have had no problems bowling straighter ones and was also finally able to get some inswing in nets on saturday....maybe on March 23rd net I will try and record all these things and post another vid trying to cover other variations...i usually bowl off-stump line with little movement...nets get a little fun where i try and get this bannana curve going...
Re: Have at it...
« Reply #31 on: March 05, 2013, 12:36:15 PM »
While I appreciate that you don't have the same run up indoors, you should try and bowl as close to normal as possible, including the run up. If you aren't bowling as fast, that's really not a concern.
Re: Have at it...
« Reply #32 on: March 05, 2013, 12:37:05 PM »
I agree but I get greedy  :D
Re: Have at it...
« Reply #33 on: March 05, 2013, 12:42:54 PM »
This was what I was going to suggest, better to lose all but 1-2 steps of your run than have to change the angle and most likely your action. In any case if you have any pace the extra distance is more likely to sacrifice speed than give any extra if you need a change of run up to get them.
Fezballoh
Re: Have at it...
« Reply #34 on: March 08, 2013, 07:18:44 PM »
Tim, you forgot to put an invoice at the bottom of your post ;)
Pages: 1 2 [3]
