Author Topic: Bat repair question  (Read 1894 times)
i12breakfree
Bat repair question
« on: March 04, 2013, 02:08:34 PM »
This needs to be repaired
Will apply the wood glue
How do i clamp it..i don't have the professional clamp/stapler thing
Manormanic
Re: Bat repair question
« Reply #1 on: March 04, 2013, 02:11:21 PM »
gorilla tape!!! ;)
« Reply #2 on: March 04, 2013, 02:12:35 PM »
string would work too
Bruce
« Reply #3 on: March 04, 2013, 02:20:58 PM »
Could use some cut up old grips
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #4 on: March 04, 2013, 02:21:48 PM »
Cut up old grips or wrap in parcel tape.
Blazer
  • Team Anti - Concave !.
« Reply #5 on: March 04, 2013, 02:22:50 PM »
Cut up small rings out of a grip , glue the crack . put the grips through .
« Reply #6 on: March 04, 2013, 02:57:36 PM »
rubber bands or old grip cut into sections. Just make sure there is plenty of pressure applied to the bat.
i12breakfree
« Reply #7 on: March 04, 2013, 03:06:16 PM »
Thanks . Will try the thick bands and will share the pics later
Cricket_PTY
« Reply #8 on: March 04, 2013, 03:39:18 PM »
Open  the crack, fill it with glue and clamp it with parcel tape or string... i prefer parcel tape....
Cheers...
« Reply #9 on: March 04, 2013, 04:03:47 PM »
Bat looks very dry. After sanding a little bit of linseed oil wouldn't hurt.
Fezballoh
« Reply #10 on: March 04, 2013, 07:59:56 PM »
All good advice. Looks like a real club mate. Try your clamping method before glueing so you know it'll pull everything back into place before you get sticky fingers. Try and leave it alone for 24 hours before sanding ;)
chaudhari21
« Reply #11 on: March 06, 2013, 12:51:25 AM »
I just did this to one of my bats few nights ago. Used string and plastic in between so the string will not stick to much to the bat. Wrapped it really tight and it turned out great. I have also have tried duct tape with plastic in between so the duct tape doesn't effect the willow when you pull it off.
i12breakfree
« Reply #12 on: March 06, 2013, 01:14:17 PM »
Glue/Clamp part is done and then did a light sanding and oiled for overnight
I have question about the surface level crack the one where putting any glue is not easy. Just have a face sheet on top will help or is there any other option?
« Reply #13 on: March 06, 2013, 01:25:26 PM »
you can water down the glue slightly so its easier for it to go in the cracks. you only want a little bit though. probably 5-7 parts glue to 1 part water. once its done to the same as you have done before and antiscuff it.
« Reply #14 on: March 06, 2013, 01:46:38 PM »
I would give it another go with the glue and clamp. Keep repeating until the crack looks sealed. Never easy to tell when it's smeared all over the place.
Try plonking a dollop of the glue directly over the crack and let gravity sink it in. Just when it looks like it's starting to harden slightly, whip on the clamp (might take up to 4 hours to harden depending on the glue, so keep checking it). Do it in stages, doing the face bit first and then the edge. Also handy (without clamp) if you want to seal the crack flush with the face to minimise it's appearance.
« Last Edit: March 06, 2013, 01:50:39 PM by uknsaunders »
