Author Topic: Bat Speed or bat weight  (Read 3917 times)
Banksy
Re: Bat Speed or bat weight
« Reply #15 on: March 28, 2013, 08:24:04 AM »
I always go for bat speed over weight, a heavy bat might help you hit the ball a little further but a fast bat can keep your wicket in tact!!!
jamesisapayne
« Reply #16 on: March 28, 2013, 10:53:16 AM »
Can't score runs if you're back in the hutch!
fasteddie
  • Straight up.
« Reply #17 on: March 28, 2013, 11:05:09 AM »
No-one has yet mentioned going to the gym!
I've recently broken out of my 2lb 9oz weight, but have been hitting the weights in the gym a fair bit over the past 6 months.
The difference to my game is marked. I now use 2lb 13oz and 3lb 1oz.
Bat speed is very important and couple with the ability to wield the weight you're onto a winner!
procricket makes a very good point. Weight on an English wicket can get you over and away, but if you're not comfortable then stick with what works.
Have you tried getting a heavier net bat from somewhere like MSR to test the water?
jamesisapayne
« Reply #18 on: March 28, 2013, 11:09:43 AM »
No need mate - I've been trying it. My M&H distinction weighs 2.14 and goes like a rocket but try playing a pull or cut I'm about 2 minutes too late, hence the reason for my post - is it better to be able to play more shots properly but hit the ball less far, than tonk it but only when driving? And get tired using it for a long time? I think yes.
« Reply #19 on: March 28, 2013, 11:46:48 AM »
In this case, I think you oughtta swap that Distinction for something! (my Powerbow) ;)
In all seriousness though, I would ditch the Distinction and go for a bat that is slightly lighter, maybe a 2.10-2.11? (About 100g in difference, which is a fair bit, but you will get more reward in terms of runs because you aren't limited to shots) I think that 2.10 is a great weight, as there is noticeably more mass in the bat, along with a decent batspeed and pickup, I would say that those 2 ounces do not really affect the batspeed. Once you get up to around 3-4 ounces above a 2.8 though, the batspeed will drop a little more noticeably, but I find that my batspeed is fine with my 2.11 Laver, so maybe pick up has a part to play with batspeed as well as dead weight. :-[
Maybe go into a retailer store, pick up a few bats, play shadow shots like the pull and cut with it, and see which one you feel best with, then weigh it. :)
fasteddie
  • Straight up.
« Reply #20 on: March 28, 2013, 11:52:34 AM »
Chad's right.
Maybe that's too much weight or the balance of the Distinction is not to your style.
They are very appealing, lots of wood, but you may be better off with a different bat.
Is the gym a viable option?
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #21 on: March 28, 2013, 01:18:41 PM »
I usually wield a heavy bat and have had trouble with a hard cut over the last couple of years.  Now I'm regularly hitting the gym, I find that I'm no longer having that trouble!
jamesisapayne
« Reply #22 on: March 28, 2013, 04:52:57 PM »
Chad's right.
With 2 kids 3 and under, in a word. No. ;)
It is a lot of wood, and a proper driving bat (which is my best and favourite shot) but after about 15 minutes I can really feel it to the point I'm starting to mis time shots.
armie
« Reply #23 on: March 30, 2013, 05:54:14 AM »
I would prefer a lighter bat since bat speed can do the trick. heavier bats are good against spinner particularly for big shots but too great a difference can make life hard for you. i would prefer better bat speed really.
