Author Topic: weight reduction  (Read 1171 times)
deanoknight
weight reduction
« on: May 05, 2013, 07:37:34 PM »
i'm wondering if there is anyony on here that can do this, i'm after 3'oz taken off my bat.
if any one can point me in the right direction...by the way its this bat
http://custombats.co.uk/cbforum/index.php?topic=23714.0
Re: weight reduction
« Reply #1 on: May 05, 2013, 08:26:54 PM »
3oz is a massive amount of weight to ask to have removed
« Reply #2 on: May 05, 2013, 08:45:03 PM »
That BAS is a stunner, but I agree with Buzz on this one!
As gorgeous as that bat looks, it is not a massive profile, and therefore 3oz of wood would leave it very skinny indeed!
« Reply #3 on: May 05, 2013, 08:47:37 PM »
Wouldn't want to ruin such a beautiful bat taking that amount of wood out :/
« Reply #4 on: May 05, 2013, 08:55:46 PM »
Id echo what other forumites have said, however, if you did want to go ahead, the easiest way would just to be concave the bat, because there looks to be little to none atm, you could probably take out 3 oz that way.
« Reply #5 on: May 05, 2013, 08:59:19 PM »
That's what was done to my Chase when I had a weight reduction, still goes just as well as it used to (if not better for me as I can pick it up now!)
If you're not bothered by having a concaved bat then it's definitely worth doing
400notout
« Reply #6 on: May 05, 2013, 09:06:52 PM »
I had my two Lavers done by Re Ink, would definitely recommend giving them a shout!
deanoknight
« Reply #7 on: May 05, 2013, 09:21:24 PM »
the only trouble i have with concaving is, although the middle is big its not long, there for wouldn't leave a lot of meat
