How Did This Happen?!
Pages: 1 [2] 3
Author Topic: How Did This Happen?!  (Read 4164 times)
SelectCricket
  • Best Batting Score - 201 Best Bowling - 2/6 LOL
Re: How Did This Happen?!
« Reply #15 on: May 28, 2013, 12:20:42 PM »
With all your bats that have broken, are they breaking in the same way?
This is the first time I have ever seen a bat break like this, let alone my own.
I have had 2 or 3 break similar to the way MagicMonty's Gray Nics has broke.
Haha that's quite a lot of cricket, how long does 1 bat normally last you? (5 nets and 3 matches isn't that much though!) You should maybe ask/look for a pretty hard pressed bat, and just try last the whole season with it. It will turn into an absolute rocket if pressed played in well. :)
Sounds like a good idea actually.
I normally always go to V Sports as he knows exactly what I like.
He normally gets a long bladed bat with a low middle and chops it down at the bottom to a normal size so the middle is extremely low.
But I suppose most bat makers on here can do that..
PedalsMcgrew
« Reply #16 on: May 28, 2013, 12:22:03 PM »
I note in your original post that you mention that the bats come 'match ready'. Does this mean your just going straight out and using them? If so then this might be your problem! You always have to knock your bat in before you use it. How much depends on the bat itself but I would never take a brand new bat into a net if I hadn't given it at least 40 mins to an hour of knocking in!
Lisa: How's my Rabbit?
« Reply #17 on: May 28, 2013, 12:22:49 PM »
Yeah, V Sports are good batmakers though from what I've heard! How much are these setting you back?
SelectCricket
« Reply #18 on: May 28, 2013, 12:23:19 PM »
regardless of how many bats you "break" this seems like either a fault in the wood or due to handle splicing etc to me. I am not an expert, but this is defo worth a replacement and chat. If the bat maker is replacing them with inferior bats then its more a cost to them as they have to keep replacing.
Tushar Sehgal, take a bow.
Couldn't of said it any better.
Was exactly what I was thinking. Just gonna have to go down to the workshop, despite knowing I may not be the bat maker's best mate, and explain that this couldn't have been my fault this time round. I doubt I am that bad of a customer as I normally buy a new one at full price again.
SelectCricket
« Reply #19 on: May 28, 2013, 12:25:16 PM »
I kind of agree with this, I am lazy and don't normally give a knock with a mallet. He knocks them in fully by hand and then I usually have some throw downs with old balls before going and using it. Suppose, being an opening bat, it's not great to go and hit new balls early on.
This one, £100, but normally between £120 and £150.
« Reply #20 on: May 28, 2013, 12:27:10 PM »
It's either not knocked in properly or driftwood. Why would you keep going back to someone who sells you inferior bats?
PedalsMcgrew
« Reply #21 on: May 28, 2013, 12:29:35 PM »
In that case, I would question the amount of knocking in the bat has had before being given to you. If you're going to go back to V sports to get a replacement then ask them not to knock it in for you and send it off to IJC or one of the many places that will knock a bat in for you and get them to do it. That way you know it will have been done properly! It takes that variable out of the equation.
If they still keep breaking then, honestly, use another maker.
SelectCricket
« Reply #22 on: May 28, 2013, 12:48:07 PM »
Would like to thank every single person who posted in this thread.
Really good advice and I shall take it on board with my future purchases.
Thanks a lot,
Matt
RossViper
  • What noise does a cow make?
    • My Excel Blog!
« Reply #23 on: May 28, 2013, 07:47:22 PM »
HANG on  a second!!!!!
What the hell is an inferior bat?????? Inferior because it brakes?! all bats brake at some point! I know I'll get lomblasted for saying this, but "inferior" is a bad term, its implying its the bats fault, and we don't know that.
I don't think its a handle issue.
Looks like it might be caused by cheap balls. What balls are you using??? Are you playing on grass wickets?
SelectCricket
« Reply #24 on: May 29, 2013, 12:42:06 PM »
Firstly, I only used the word inferior when I said that is what he replaced me with before, by that I mean that I bought a grade 1 or 2 bat and he replaced it with a 3 which has about 4 grains and wasn't to my spec.
Secondly, I broke it playing with the top of the range ECB ball that is standard in all ECB County Cup Matches and other than that ball, I have only batted against tifflex balls.
I am pretty sure they all set you back at least £15/£20 a ball so I doubt it's that factor.
« Reply #25 on: May 29, 2013, 12:52:33 PM »
I'd say a handling issue when it splits like that, from the splice area.
SelectCricket
« Reply #26 on: May 29, 2013, 12:55:37 PM »
Thought it might be, thank you!
Going down to coventry tomorrow so will update this post on the progress...
RossViper
    • My Excel Blog!
« Reply #27 on: May 29, 2013, 08:17:21 PM »
the word was used, or quoted in at least 4 posts, and clearly given a different context.
If you keep braking bats, this issue is with you, not the bats - often happen to people with fast hands.
SelectCricket
« Reply #28 on: May 30, 2013, 01:29:09 PM »
Just to update this post..
Took a trip down to V Sports today, spoke to Richard (the batmaker) and he said despite my habit of bat breaking, this bat would have broke in the hands of any batsman.
Replacement being sent to me next week. Top bloke.
PedalsMcgrew
« Reply #29 on: May 30, 2013, 01:36:20 PM »
Good stuff, great service! Get it knocked in properly though! That way if anything does happen you know it's not down to the bat not being ready!
Pages: 1 [2] 3
