Author Topic: What to do.  (Read 1479 times)
countycricketplayer
What to do.
« on: June 23, 2013, 10:21:23 AM »
Hi,
Basically my second toe, gets very painful when I bowl.
I wear asics gel speed menace boots.
What should  I do?
Gelds
Re: What to do.
« Reply #1 on: June 23, 2013, 10:28:05 AM »
Sounds like your shoes are not fitting properly. Have you tried thick socks or multiple pairs of socks?
Re: What to do.
« Reply #2 on: June 23, 2013, 01:00:58 PM »
Get new shoes??
Cut a hole in your current shoes??
Amputate that toe??
vasiraju
Re: What to do.
« Reply #3 on: June 23, 2013, 04:26:41 PM »
Are you getting just a pain or is there any burns? you can try some broad and flexible shoes than the ones you currently use. May be something without the protection layer in the front of toes while bowling or fielding can also solve the issue.
Old boy
  • The older I get, the better player I was.
Re: What to do.
« Reply #4 on: June 23, 2013, 09:56:55 PM »
the fact its your second toe could suggests maybe your toes are pressing together, which may be a sizing issue, the asics are a wide fit though. if you have a long second toe it could also mean your foot is sliding too far. a way to fix the sliding is to lace your boots differently,  i'll try to explain but its one of those things that are much easy to show. make a loop using the last two lace holes on each side of the shoe then feed the lace across through the opposite hoops as you pull the laces down they will "lock" preventing your foot from sliding forward. you then just do a normal lace tie.
Re: What to do.
« Reply #5 on: June 23, 2013, 10:03:11 PM »
most fast bowlers get this, they cut a hole where there middle toe is and its fine, never tried it but pros swear by it
coverpoint_pro
Re: What to do.
« Reply #6 on: June 23, 2013, 10:23:54 PM »
Cut your toenails
timshort15
Re: What to do.
« Reply #7 on: June 24, 2013, 07:19:30 AM »
I second the advice about cutting your toenails, the third toe one my left foot used to bleed every time i bowl till i realised this was the problem
