Can it be repaired?
Author Topic: Can it be repaired?  (Read 4982 times)
scottish_slogger95
Can it be repaired?
« on: July 11, 2013, 08:25:09 PM »
Club pro said If I could repair this, I would be able to keep it. Any suggestions on how to repair it? I don't know how to do this one
Also I have spare bits of english willow wood around the house but I don't have the chunk from this bat
joeljonno
Re: Can it be repaired?
« Reply #1 on: July 11, 2013, 08:37:27 PM »
Get a load of glue in the bit that's still there.
Do you have the missing piece?  If so, once the middle bit is sorted, glue it back on, maybe some dowels or a screw, perhaps just twine it.  If not, square off and use a piece from an old bat.
Toe will not be brilliant, as long as you save the middle.
Twitter - @joeljonno
« Reply #2 on: July 11, 2013, 09:01:35 PM »
Mate can easily be repaired, as Heworth said, square it off with a chisel, after glueing the middle bit, cut a piece to size and glue, then twine tape and any thing else to hold it together
« Reply #3 on: July 11, 2013, 09:13:29 PM »
I think if you shave off a bit of wood so that the joining part is straight, then it's easy to cut out a bit of wood which matches that shape. :) It should be straightforward enough, but might take a while! Also, while you're at it, get rid of that horrible scuff sheet! ;)
« Reply #4 on: July 11, 2013, 09:32:46 PM »
If you have the piece that has come away then yes quite easily just by glueing and binding it together then sanding will look good as new.
If not then still be done but I would get a pro to do it and give it a full refurb, would cost about £40 and you would get a new looking M&H solution G1 for that if the pro gave it to you. You lucky man.
« Reply #5 on: July 11, 2013, 09:40:26 PM »
Got to agree that's a great looking stick and a easily fixable as soulman said get it done professionally and you have a great bat back
scottish_slogger95
« Reply #6 on: August 04, 2013, 08:22:23 PM »
just thought I'd update this thread. Millichamp and hall got the bat and said its not worth repairing as it would only last a few games :( Is there any other options for this bat? It pings like crazy so I really want to get some use out of it
« Reply #7 on: August 04, 2013, 08:25:37 PM »
Who's your club pro?
scottish_slogger95
« Reply #8 on: August 04, 2013, 08:27:02 PM »
Cam Farrell, why?
« Reply #9 on: August 04, 2013, 08:43:30 PM »
No reason
coady123
  • Colts
« Reply #10 on: August 04, 2013, 08:45:29 PM »
my bat did that glued it a few times but kept coming off and finally had to say goodbye to it
SkipperJ
« Reply #11 on: August 05, 2013, 03:28:27 PM »
Check with Dean @ Vulcan, he might be able to help. Nice bat, don't give up on it just yet ...
CBF gave me BAD real bad!
RossViper
  • What noise does a cow make?
    • My Excel Blog!
« Reply #12 on: August 05, 2013, 07:32:32 PM »
Piss, it can be fixed, do you have the other bit?
How long it lasts is in the lap of the gods
« Last Edit: August 05, 2013, 07:34:16 PM by RossViper »
scottish_slogger95
« Reply #13 on: August 05, 2013, 08:01:36 PM »
Afraid not mate, thats what makes it hard. I think M&H dont want to be responsible for it if it brakes again within a few games so I think they dont want to do it
scottish_slogger95
« Reply #14 on: December 06, 2013, 02:11:53 PM »
Right, after several months sitting in M&H I finally remembered about this bat and asked if they could ship it back. It's arrived back today. Going to have a crack at fixing this. Its too good a bat not. Honestly the performance on this bat is insane, I just hope it turns out ok!
