Author Topic: Consistantly bowling off cutters..  (Read 4029 times)
AndyR
« on: July 12, 2013, 12:12:34 PM »
For the past 2 and a half years 80% of the balls I bowl are off cutters due to my wrist "sliding" to the right upon release instead of being straight up.
Id like to think im fairly "quick" but iv been told numerous times if I had come to a solution to stop bowling off cutters id have that extra bit of a nip when im bowling.
Anyone else had this problem or a similar one to it?
Re: Consistantly bowling off cutters..
« Reply #1 on: July 12, 2013, 05:47:46 PM »
You could lock your wrist before delivery..that is have it bent backwards in your run up and arm swing...some bowlers do that to stop wrist from sliding..lets hope the pics help explain...
Unlocked/straight wrist- wrist is right behind the seam
Locked wrist - wrist is locked so that the top of your arm swing the palm/ball is facing the sky...wrist will straighten as you swing forward and release and helps in avoiding sliding..
http://www.videojug.com/film/how-to-grip-the-ball-to-bowl-fast
« Last Edit: July 12, 2013, 05:50:17 PM by tushar sehgal »
countycricketplayer
« Reply #2 on: July 12, 2013, 06:00:34 PM »
tushar's  got everything there
RossViper
  • What noise does a cow make?
    • My Excel Blog!
« Reply #3 on: July 12, 2013, 08:17:58 PM »
not really come across this before, a video of your action would really help.
It could also me your action, arm movement etc.
Dhiraj
« Reply #4 on: July 15, 2013, 09:01:17 PM »
Try watching a couple of Andersons video on youtube or may be Mathew Hoggard as well..
countycricketplayer
« Reply #5 on: July 16, 2013, 07:37:55 PM »
isn't it a case of cocking your wrist ?
« Reply #6 on: July 16, 2013, 08:43:01 PM »
Try squeezing the ball a touch harder with your Index finger, that's a preget common way to stop the wrist falling away at the point of delivery.
scottish_slogger95
« Reply #7 on: July 16, 2013, 08:58:46 PM »
I also have a similar problem. I don't seem to be able to release the ball with my fingers straight so I loose a bit of pace. Any suggestions on how I can release it straight or is it the same advice as above lads?
Jenko
« Reply #8 on: July 17, 2013, 01:27:08 AM »
I have had this problem. Try running in a little slower and standing nice and tall in your delivery stride. Often when I bowl cutters/scrambled seem every ball it's because I'm falling away thus my body overcompensates by dragging the wrist down not square. When I stand taller and get my arm high I can swing it both ways but when I go for that extra effort and fall away cutters are the end result. Video would be good though
AndyR
« Reply #9 on: July 25, 2013, 10:59:37 AM »
Thanks for the reply's iv not been able to attend many net sessions however iv adjusted my action accordingly in a match and I can definitely see a change now that the seam is straight up and now genuinely swinging the ball.
Im kind of disappointed as I thought that the pace that I can release the ball doesn't seem any different; im just assuming I need to perfect my action to achieve extra pace?
Jacky
« Reply #10 on: July 25, 2013, 12:12:08 PM »
It's most probably due to the looseness of your wrist at the point of release, fix that but remember how to bowl the off-cutter, its a great weapon for a fast bowler.
