Author Topic: Weight reduction .. worth it?  (Read 2235 times)
ajmw89
  • 4XI ornament
    • Wright Cricket
Re: Weight reduction .. worth it?
« Reply #15 on: July 18, 2013, 03:20:17 PM »
If you get any taken off, the toe could lose a little bit to help pickup.  Seems to have a fat toe!
mini998
« Reply #16 on: August 23, 2013, 04:40:29 PM »
Does anyone know (tried before?) how much weight I can get rid of by removing the anti scuff sheet and the Toeteck toe guard from this bat?
trypewriter
« Reply #17 on: August 23, 2013, 04:42:29 PM »
Maybe 2 oz max
mini998
« Reply #18 on: August 23, 2013, 04:45:08 PM »
2oz just might do the trick TBH.
trypewriter
« Reply #19 on: August 23, 2013, 04:47:56 PM »
I think most scuff sheets are rated to add 1 oz
« Reply #20 on: August 24, 2013, 01:04:45 AM »
Scuff sheet = roughly 12-16g, which is half an ounce, plus the toe guard, which is, let's say for argument's sake, 10g. You'll be losing 1 oz at the very most I think. How many grips do you have on the bat?
mini998
« Reply #21 on: August 24, 2013, 09:32:34 AM »
I got two,  but handle is very very thin so I need two atleast
« Reply #22 on: August 24, 2013, 09:38:32 AM »
Weight reduction is fine if it done right and weight evenly reduced
As others have I have used Dom who was brilliant and a brilliant finish and also Ryan before and b3 did my crown willow and do it well
If done correctly no noticeable performance loss is found but I would check with the person doing it as some bats don't afford 2oz coming off them mostly small edges and large concaved bats
