Author Topic: why does a bat keep doing this?  (Read 4733 times)
Re: why does a bat keep doing this?
« Reply #15 on: July 30, 2013, 03:21:11 PM »
Although the grains go through the toe, doesn't the willow fibres go in the opposite direction hence why bats feather through tapping and in extreme cases split like this.
coady123
  • Colts
« Reply #16 on: July 30, 2013, 03:28:00 PM »
It's a Epic 808 5 star.  Could be that then. Gonna glue it tonight and see how it is for Saturday.
yeah glue and clamp should do that's what iv done , also when getting a new bat linseed oil might stop this
« Reply #17 on: July 30, 2013, 03:32:54 PM »
GMs tend to have toe guards and faceguards, so linseed oil wouldn't be any use. The only thing linseed oil would stop is moisture uptake at the toe, if you repeatedly hit the toe of your bat, it will eventually crack.
Perhaps get some twine and wrap it round the toe and glue it? I see it done on bats, and apparently it helps hold the toe together.
« Reply #18 on: July 31, 2013, 12:02:29 AM »
few of my bats have done this, and its from trying to spank yorkers way too hard. basically glue and clamp, then I would stick twine around the toe, as chad said, I did this on a few bats and it helped loads
Hammer Cricket
« Reply #19 on: November 20, 2013, 03:00:40 AM »
What do companies like yourself do with returned bats?It's something I've always wondered. Obviously there'll be plenty returned that aren't repairable, but there must also be plenty that are but get replaced anyway.
Hammer has a 30 day replace or fix warranty... If we can't fix then we replace... If it's between the 30 day replace and 6 month window then we fix..
Most cracks are fixable.
RaepTiem
« Reply #20 on: November 20, 2013, 06:14:16 AM »
what sort of ball do your club use. could be a factor if they are rubbish. if the balls aren't the problem, cover your toe with fibreglass, it's what i do. my mates tell me it makes the bat look wierd, but in the end you save the trouble, the money, and you prolong its life and performance isn't affected.
joeljonno
« Reply #21 on: November 20, 2013, 07:18:52 AM »
The league balls aren't great, but that has already been factored in. He didn't use it much in that league.
Cant see how tape would help as it already had a toe guard fitted when this happened.
I think it is partially to do with the way the bat has been made and a fair bit to do with the user.
Twitter - @joeljonno
Vulcan Cricket
« Reply #22 on: November 20, 2013, 07:58:59 AM »
That all
joeljonno
« Reply #23 on: November 20, 2013, 08:20:12 AM »
That all
Not the best is it. What about postage times and if I bought it in the end of season months. Could be 6 months between purchase and first use.
