How to counterbalance a bat
Author Topic: How to counterbalance a bat  (Read 14255 times)
yvk3103
Re: How to counterbalance a bat
« Reply #15 on: September 17, 2013, 03:03:20 PM »
Btw, there are several health reasons for my using lead tape.
The lead strips that golfers use is a bit different that the normal lead tape. The normal lead tape is the cheaper option of course.
To get the counter balance correct it has to be at the very top of the handle. Eg Newbery Merlin.
« Reply #16 on: September 17, 2013, 03:08:44 PM »
Thanks Chad.  Not had to do this on a bat yet but worthwhile knowing.  Something new for the forum to be pinned in the future?
Ah right, just find it something useful to know how to do, as if you have
I have never found lead tape to be more effective than rings cut from thick grips.
Personally I have not seen a pro using lead tape yet.
Ask batmakers and they would all tell you to use grip and tape.
As for cost, if we can spend £300 on a bat then a £5-£6 to get it to the desired pick-up shouldn't hurt.
Haha, yes, I wouldn't mind using £5-6 to get a desired pick up, but your original point was not to waste money on lead tape. ;)
The point I'm making is that lead tape is more dense, therefore won't 'poke out' as much for the same weight of grip added onto the end of the bat. Essentially another way of skinning a cat. Good thing about grips is that you can add smaller amounts of weights in rings, but it will stick out more. Saying that, you could easily do a mixture of both, or even get slightly thinner lead tape. I'm sure if you asked a batmaker which was the most efficient way, they would probably say both ways work. All you're doing is adding weight onto the end of a handle! Also still more cost efficient for the weight added. ;)
« Reply #17 on: September 17, 2013, 03:14:11 PM »
Fair point, may have forgotten to tell folk to wash their hands after using lead. I have no idea about golf, but the tape I got was pretty decently priced, perhaps the ones that pro golfers use are different in that they may be galvanised for better durability or something like that. You end up wrapping it in insulating tape anyways, so it shouldn't really have any affect at all. :)
And yeah, mentioned that at the end of the post, and that's what I altered my one to be like. It all depends on what you like to be honest! I think the reason I didn't put it on at the start was because I saw a number stamped on that area of my Hawk handle, but I guess since it's now pictured, I don't need to remember it! ;)
« Reply #18 on: September 17, 2013, 05:47:35 PM »
If I spent 300 on a bat then I would be pretty annoyed if the pick up wasn't as desired without adding things!
RaepTiem
« Reply #19 on: September 18, 2013, 08:15:54 AM »
I would go into the shop and make sure i buy the right bat, it is a large investment and you should get it right the first time round. That being said, im a very bare bones cricketer who does not put as much effort into his kit as others on the forum.
