Butterfly
Pages: 1 ... 13 14 [15] 16 17 ... 39
Author Topic: Butterfly  (Read 156582 times)
Re: Butterfly
« Reply #210 on: March 29, 2014, 08:32:24 PM »
older trees will have more grains.
the tightness of the grains is frequently caused by being higher up the tree, which is which bats with lots of grains can be more susceptible to breaking.
Re: Butterfly
« Reply #211 on: March 29, 2014, 11:03:25 PM »
I thought one grain was one year's growth?
« Last Edit: March 29, 2014, 11:13:36 PM by Bats_Entertainment »
Re: Butterfly
« Reply #212 on: March 30, 2014, 03:03:56 AM »
Yes spend a bit longer with the mallet then get an hours worth of throw downs with descent old balls. It may not take too long to knock in, you will tell by the feel of it and looking as the face isn't showing signs of dents. Small surface cracks are good as it shows a really nice piece of responsive willow.
what about vertical cracks going along the grains? i have had a few bats, where it almost looked like the strips of sapwood between each grain were separating from one another. initially freaked out, but performance seemed to actually improve.
Re: Butterfly
« Reply #213 on: March 30, 2014, 08:08:57 AM »
That is gold brokenbat. That is what you want. :)
Aldred Cricket Bats
    • Aldred Cricket Bats
Re: Butterfly
« Reply #214 on: March 30, 2014, 08:34:46 AM »
Exactly all the best bats I've had and I've had some good ones have gone like these, the key is to look after them through the season and out of season. A nice light sanding and a little smear of oil will keep it going nicely. Some of the bat faces don't stick very well when oiled but if you let it really soak in for a week or two you can put a face on ready for the season.
Maybe I should do a little video on basic maintenance
Re: Butterfly
« Reply #215 on: March 30, 2014, 08:52:46 AM »
Quote from: Aldred Cricket Bats link=topic=27867.msg468477#msg468477
[/quote
That would be good, also one showing a good bat opening up would be good for people.
Re: Butterfly
« Reply #216 on: March 30, 2014, 09:42:33 AM »
indeed and trees are wider at the bottom than the top!
Re: Butterfly
« Reply #217 on: March 30, 2014, 10:32:52 AM »
OK.
Re: Butterfly
« Reply #218 on: March 30, 2014, 10:34:35 AM »
The often misused term 'opening up' actually means this, brokenbat.
« Last Edit: March 30, 2014, 12:38:00 PM by Bats_Entertainment »
Number 11
Re: Butterfly
« Reply #219 on: March 30, 2014, 10:21:08 PM »
In the 1920's some 200 willow setts from Cowfold & Beltring were planted opposite the cricket field in Robertsbridge, but they were found to be hard and of poor quality. More recently however a tree was cut in Robertsbridge that was nearly fifty inches around the trunk after only nine years. Len Newbery, who was manager of Gray Nicolls until his death in 1976 said "The timber of the salix alba caerulea is distinguished by a bright orange stain that is known in the trade as the butterfly stain. when these stains appear on the blades of bats the players often reject such bats thinking that they are faulty whereas they are the hallmark of simply the finest willow."
50" circumference trunk in 9 years, that pretty fast growing.
That's about 16" diameter, splits down into 8" clefts with 9 grains. Chop off the inside wedge and cleanup the bark edge and that'll give you roughly 4 grains. Reckon it'll ping like a trooper.
I also see the price of butterfly going through the roof, expect it to reach £400+ in the next year or so for a finished bat.
Re: Butterfly
« Reply #220 on: March 31, 2014, 07:51:51 AM »
With wide grains.
i12breakfree
Re: Butterfly
« Reply #221 on: March 31, 2014, 12:17:08 PM »
Looking forward to seeing the new Willow
Aldred Cricket Bats
Re: Butterfly
« Reply #222 on: March 31, 2014, 06:19:06 PM »
Ok here's a batch off down to Cheltenham on Wednesday all the ranges in butterfly and a gold sovereign in a players grade plus softs. A great set of kit, bats all made ranging between 2-9 and 2-11 with lovely pick ups and the players grade is an absolute peach plus the new made in England sticker on the handles  :D
Re: Butterfly
« Reply #223 on: March 31, 2014, 06:20:26 PM »
Aidy? ;)
acko109
Re: Butterfly
« Reply #224 on: March 31, 2014, 06:31:21 PM »
bat in the middle looks like a special stick !
