Author Topic: Bow  (Read 3929 times)
CrickFreak
Bow
« on: January 24, 2014, 05:56:42 PM »
I have been reading and doing some research on how the bow effects the performance and the pickup of a cricket bat. Some say it adds power, some say it helps pick up.
Looking at some of the pics of pros bats, they seem to have a very pronounced bow especially SRTs bat.
If its a good thing to have, then why all bats are not bowed to maximum possible. Is it lack of skill or its just not worth doing it.
What are your thoughts on bowed bats and advantages or disadvantages of it. I have not seen or read any negative comments about bowed bat profile.
And do you like it or dont care. And why?
PS: Apologize if this has been discussed before. Please point me the thread if you can. Thx
« Last Edit: January 24, 2014, 05:59:10 PM by CrickFreak »
Re: Bow
« Reply #1 on: January 24, 2014, 06:02:50 PM »
I personally prefer a bow, helps me go over the top, and adds decent pick up to a 3lb plus bat.
But, with the increased want for bigger edges, and the flatter profiles bought about because, it seems very pronounced bows are disappearing from the shelfs.
In fact I believe it's just be asain made bats that still offer a pronounced bow.
Re: Bow
« Reply #2 on: January 24, 2014, 06:04:25 PM »
I've never used a bat with a pronounced bow to it
I'm sure if it was such a performance / pick up aid, all bats would exploit it?
Wickets-then-runs
Re: Bow
« Reply #3 on: January 24, 2014, 09:48:33 PM »
The way James Laver explained it to me was: the more the blade is bowed, the better the pick up(to a point). However for every mm the blade is bowed, the length of the sweet spot is reduced. Scat and Bradbury (now) do not bow there blades for this reason as the blade is put through a huge downward force to put the bow into it.
Re: Bow
« Reply #4 on: January 24, 2014, 10:14:13 PM »
I suppose in some respect, it could help a really heavy bats pick up, but then wouldn't you just use a slightly lighter bat with a larger sweet spot ?
Jimmyg
Re: Bow
« Reply #5 on: January 24, 2014, 11:27:36 PM »
I know it is commanly repeated that a bow helps pick up, but how and why does it make the pick up lighter?
Re: Bow
« Reply #6 on: January 25, 2014, 01:17:08 AM »
Depending on who makes a bat, the bow is imparted in different ways. The result is different performance from different makers.
CrickFreak
Re: Bow
« Reply #7 on: January 25, 2014, 01:30:37 AM »
What is not clear is  - how much bow, which part and how it effects pickup and performance.
Thinking of ordering a custom bat, never gave much importance to bow, but his time want to include it in the requirements list :)
But not sure what it will do to the bat and what to ask for :D
Re: Bow
« Reply #8 on: January 25, 2014, 07:13:29 AM »
the bow gets the weight of the bat above your hands faster, making it appear to pick up better.
on the bow, it is worth elaborating in that some firms press the bow into the blade, others cut the bow into the blade before pressing.
« Last Edit: January 25, 2014, 07:15:50 AM by Buzz »
ogroupleader
Re: Bow
« Reply #9 on: January 25, 2014, 10:00:25 AM »
My 2 favourite bats both have massive bows in them. Thruxton SPS and Black Cat Shadow.
Wickets-then-runs
Re: Bow
« Reply #10 on: January 25, 2014, 11:02:59 AM »
in them or on them?  :)
Re: Bow
« Reply #11 on: January 25, 2014, 11:16:56 AM »
When I was a junior/coming to adult, I had a Easton I bought at a car boot. Had such an extreme bow, and a loved it. Middle wasn't overly large, but I rolled with it, until it did a Carberry.
By then Easton had vanished. So was gutted. Discovered recently aero bought out Easton, but not sure aero have released any bats?
On a seperate not. Gray nics custom bats say "choose your bow, slight, pronounced or extreme!"
Re: Bow
« Reply #12 on: January 25, 2014, 11:22:48 AM »
To add bows can accure naturally over time as well.
I prefer a flat face with a bow cut into the edges to make it appear there a bow.
Also some forward setting handles can make it appear bowed when it is not.
Re: Bow
« Reply #13 on: January 25, 2014, 11:34:13 AM »
My latest b3s have forward set handles, as they don't add bow to the the bats.
ogroupleader
Re: Bow
« Reply #14 on: January 25, 2014, 11:35:41 AM »
Sometimes both. You would def get more runs if you went out to bat with a bow tied to the SCAT.
