Author Topic: Flat or round???  (Read 5483 times)
alee
Re: Flat or round???
« Reply #15 on: March 20, 2014, 11:26:12 PM »
I prefer round face. Not fond of the sharp edges,
« Reply #16 on: March 21, 2014, 12:03:52 AM »
The best bats I've used have all had a rounded face. I'm not sure how rounded, and it could just be coincidence. Personally, in terms of looks, I quite like the flat face when looking at the side on profile, as it does make the bat look much more impressive, (Compare Icon F2 to Icon F7) but in terms of looking at it from the face, a mix between the two is my favourite. (F4.5) I don't mind a flat face, but it does give you more of a twisty feel when you hit off centre. Would always recommend you go with an oval handle when using a flat faced bat, as that helps prevent twist, and (from observations) also not to have it too concaved. (Changing grip relatively regularly also helps) I think a lot of it is in the mind, and what you feel most comfortable with, but the most noticeable difference in playability is the twist.
Colesy
« Reply #17 on: March 21, 2014, 12:48:43 AM »
Round, it's purely aesthetic but it makes me feel warmer inside
Number 11
« Reply #18 on: March 21, 2014, 02:15:51 AM »
Rounded definitely. The edge is an essential part of my batting technique, if it was square i'd be breaking bats left right and centre. ;)
« Reply #19 on: March 21, 2014, 06:42:12 AM »
Given that it makes absolutely no difference to my ability or how far I hit the ball,  I don't give two hoots and wouldn't specify one or the other.  My top three bats are a mix of flat and traditional face rounding.  They all ping nicely.
To sum that up,  I don't care,  as I don't believe from my experience that there is any extra twisting or performance from a flat face.
« Reply #20 on: March 21, 2014, 07:23:30 AM »
we should also mention that flat faces are relatively new so most of us will have happier memories with round faced bats
amritpremi
« Reply #21 on: March 21, 2014, 07:43:40 AM »
I prefer flat or nearly flat face, I feel using a round faced bat I edge more often or edged ones fly to slips more often. With Flat faced bats my edged ones fly more towards the point and provides me sort of surety. Maybe it's all in my head but the face of the bat sort of affects my batting slightly. The flatter face bat with round handle twists sometimes when off centre shots are played with soft hands, could be avoided/reduced with oval handle. I have & played with both flat & round face ones and I definitely prefer flat faced bat.
fasteddie
  • Straight up.
« Reply #22 on: March 21, 2014, 09:33:04 AM »
I'm on the round face team.
I'm not one of extra wood on the edges, which is the main selling point for flat face. I'd rather have it in the middle.
Also, I run the ball off the face a lot, so a rounder face gives me more control.
Giraffe208
« Reply #23 on: March 21, 2014, 09:38:01 AM »
+1 for rounder faces
« Reply #24 on: March 21, 2014, 10:23:49 AM »
Not fussed either way, but I liking the 4.5/3.5 halfway house. My b3 and I think my Ayrtek have this almost flat face. As I understand it flat faces give you (potentially) more control over the placement of a shot. As opposed to the ball hitting a rounded face and sliding off.
« Reply #25 on: March 21, 2014, 11:02:24 AM »
If you are a much better batsman than most of us... And honestly, at our level, the three-seven degrees difference really makes no odds...!
