Pages: 1 [2] 3
Author Topic: Is a skinny toe really a risk?  (Read 6522 times)
tejasapatel
Re: Is a skinny toe really a risk?
« Reply #15 on: April 07, 2014, 07:43:42 PM »
I don't like bats with heavy pick up but I also hit a few at the toe at least 1/10. I would go with something not too thick but gives me comfy feeling that I won't break the bat.
- Ian Botham
« Reply #16 on: April 07, 2014, 07:44:21 PM »
« Reply #17 on: April 07, 2014, 07:45:54 PM »
I have picked up your bat Chris a very nice bat indeed Ryan has done there a future star that lad is.
« Reply #18 on: April 07, 2014, 07:52:53 PM »
Its all down to perception when you look down.
More wood in the toe means it's thicker (naturally). The average punter will think thicker toe = less likely to break as there's more wood there.
More wood = stronger, so they'd therefore assume thicker toe = better/stronger/lasts longer etc.
I honestly don't think the average punter cares.  I can't tell the size of my toe when looking down the bat. The meat gets in the way.
« Reply #19 on: April 07, 2014, 08:20:10 PM »
In which case I'm just as clueless on this as you are mate ???
Bruce
« Reply #20 on: April 08, 2014, 08:09:40 AM »
Another with a large toe is the Laver Legacy, huuuge.
« Last Edit: April 08, 2014, 08:23:59 AM by Bruce »
MD2812
  • Hi, I'm Joe
« Reply #21 on: April 08, 2014, 09:29:40 AM »
Why does it give you more confidence?  (I genuinely don't understand this)
My Newbery GT had a thin toe, blocked a yorker and it cracked. across the toe rather than front to back, 1 cm along the toe then 1cm up the inside edge perfectly in the middle of the toe.
It's been repaired and never a problem again, but I'm scared of the ball hitting that area of the toe.
Even if i'm completely wrong, a thicker toe for me feels more sturdy and less likely to crack through the toe.
I feel more confident with a thicker toe, don't care if i'm right.
A cricket bat placebo if you like.
« Last Edit: April 08, 2014, 09:32:36 AM by MD2812 »
Gingerbusiness
« Reply #22 on: April 08, 2014, 10:05:52 AM »
Never seen a Laver without a reasonable sized toe... Through to be fair, only place in the world where pitches place, generally, as slow and low as they do here in the UK.
Or could be the Millichamp and Hall factor. Never see a small toe from them these days.
« Reply #23 on: April 08, 2014, 10:42:14 AM »
the grains running through the toe are a factor.
I was told by a head bat maker that .................
If there is a grain that goes off wonky towards the edge then it is more likely to split there ....  if they are perfectly straight its less likely to crack.
« Reply #24 on: April 08, 2014, 11:16:29 AM »
Straight prominent grains through the toe are a factor a thin toe with grains running through it is less likely to split than a thicker toe with poor grainage.
toby176
« Reply #25 on: April 08, 2014, 11:53:31 AM »
Can anyone post a picture of a particularly thin toe?
Liam-SCCC
« Reply #26 on: April 08, 2014, 12:23:32 PM »
I can when I can get to my kit bag!
Top Score: 102*
Best Bowling: 7/29
« Reply #27 on: April 08, 2014, 12:37:32 PM »
The thinnest that was in my collection(now sold)
Cedrictoad
« Reply #28 on: April 08, 2014, 01:44:35 PM »
I am in the Michael Clarke camp... thin toe is better... I would rather have the weight and power where it matters.  But I use particularly light bats so I am probably more conscious than most of keeping the weight down.
You are much less likely to score serious runs from a Yorker so why do you need a thick toe?  Just dig it out and wait for the next ball.
But if I could wield a 3lb monster then I wouldn't care!
« Reply #29 on: April 08, 2014, 10:08:13 PM »
Pages: 1 [2] 3
