Author Topic: Unbinding the bat handle to alter the flexibilty  (Read 1257 times)
Nmcgee
« on: April 27, 2014, 10:19:57 AM »
I've presented this question to a couple of bat makers, but would like to hear from you guys.
I have two bats that have very stiff handles. Will taking the binding off and replacing with taping benefit the flexibility of the handle? The best bats I have feature standard cane handles with noticeable flexibility (think Lavers). Some high quality bats I own have handles that are rock hard.
I've seen video of Mike Hussey removing his binding and replacing with sports strapping tape but I think this is to reduce the thickness of the handle.
Back yourself.
Butterfingerz
    • Stealth Cricket
Re: Unbinding the bat handle to alter the flexibilty
« Reply #1 on: April 27, 2014, 10:23:03 AM »
It's something Michael Clarke does also. Indeed the bonding will make a difference, how much depends on the quality of the handle itself
Nmcgee
« Reply #2 on: April 27, 2014, 10:26:18 AM »
The strength of the handle is compromised?
Back yourself.
« Reply #3 on: April 27, 2014, 10:40:15 AM »
I used to unbind the top half of the handle and found noticeable flex but it depends on what handle you are using.  I found sareen to be decent for flex after the  process but ranson handles didn't.
After a test period of over a year I would stick to binding  the main reason players do it is to alter the feel of the handle and use tape to get the correct shape unless they carry a handle set to there batmakers which I have seen a few times.
Yes the handle is compromised with unbinding.
« Last Edit: April 27, 2014, 10:44:32 AM by procricket B3 »
benny231
« Reply #4 on: April 27, 2014, 10:49:25 AM »
I would imagine that players like Clarke and Hussey can do this without worrying about decreasing the life expectancy of the bat due to their sponsors..
« Reply #5 on: April 27, 2014, 10:52:39 AM »
De stringing a bit does not add that much flex trust me on that one.
Nmcgee
« Reply #6 on: April 27, 2014, 10:54:35 AM »
So, better off simply exercising the handle. Any guidance on this?
Back yourself.
Pelican042
  • Best bowling 1-4
« Reply #7 on: April 27, 2014, 12:25:18 PM »
Stand on the handle
"Just remember the best shot in cricket is the leave" *leaves on middle stump*
« Reply #8 on: April 27, 2014, 02:00:18 PM »
Agreed standing on handle will loosen it up and provide you with whip.
tejasapatel
« Reply #9 on: April 27, 2014, 02:23:00 PM »
Stand on the handle
Seems like this is your fav suggestion when it comes to loosening the handle.
- Ian Botham
