Long day of refurbs/repairs (And the reason why I hate heartwood sometimes!)
Author Topic: Long day of refurbs/repairs (And the reason why I hate heartwood sometimes!)  (Read 3833 times)
Hi guys, been a little while since I posted a topic, and also been a while since I had taken out the orbital sander and other stuff for refurbs, so I decided that I'd spend some time cleaning up/repairing some bats, altering them slightly both cosmetically and in terms of shape. Did this all in a few hours over 3 days! (Had to wait for glue/oil to dry, and my arm to recover from the orbital sanding!)
Here are all the bats I did some work on:
Slight reduction on the Helios Atlas:
Before
After
Slight reduction on the B&S:
Before
After
Repaired the delamination on the TON, along with removing some stickers, ovalling out the handle, cutting down the tip of the handle with a saw and compensating the weight lost with some lead tape:
Ovalled out the handle on a very special BAS:
Put glue in the cracks of my 3 match old SS LE, clamped the big crack, sanded down, removed some stickers and oiled:
A bit dry...
After a good bit of gluing, orbital sanding, fine sanding and oiling:
I've used that SS in 3 matches, scoring 65, 23 and 86*, so it's been a good companion! (The 65 and 86 were new top scores!) A shame to see her in this state really, but it shows why I prefer no heartwood! The outside edge is unscathed, so I should probably get bats with heartwood on that edge (if any) in the future! To be fair, I should have probably prepared it for a bit longer, but it was quite dry, so is bound to happen, especially if you use Lords balls in your league! Going to maybe give it another coat of oil and leave it for two weeks before scuffing it - it deserves a little break!
The TON and SS bats look a LOT better with some of the stickers missing IMO, just makes it look much less cluttered! The reason I cut down the handle length of the TON was partly because I wanted to try a SSH, but also because the TON handle was a little longer than most SH bats, but the blade was just a touch shorter. It just felt a little odd in the stance, so I decided to experiment on it rather than sell it, especially since the repair came out really well! I think it's only the second bat I've heard of needing a repair before it was actually used! (Okay, was used for like 8 balls between myself and King Pair, but needed the repair before that!)
I reduced the toes of the Helios and the B&S bats, as they were both a touch heavy, and I found that I actually hit a little higher than I used to now, after looking at my SS scuff sheet. They both feel great now, especially the Helios! It feels like holding a completely different bat now, but it still pings all over like it used to! (The weight taken off was actually quite little, not sure of exact measurements, but I changed the grip to a slightly heavier one too, and it feels much better!)
The rest of the bats (Slazenger, Helios Midas stickered Bulldog Amplus and Kangroo) were just generic things like edge rounding, scuffing and oiling.
The orbital sander I use I find is great, it has 6 speed options, and is really good at removing the residue left behind by stickers and scuff sheets. (Don't trust myself with white spirits!)
http://www.amazon.co.uk/gp/product/B005GIU33U/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
It's only £62 now, and does a great job! The only thing is that you will probably need a different hoover connector to plug to the sander if you're using it indoors. (I just use it outdoors, so I don't need one) It also helps shape shoe goo at the back of the toe, so it's more of a perfect fitting toe guard! (Completely cosmetic, and should only appeal to those with a serious OCD about how their bat looks!) Maybe it could be used to shape a proper toe guard carefully...
Sorry if these kind of threads bore you, but I think some folk like them. :) Please make any suggestions you feel will help me improve my refurbs!
« Last Edit: July 04, 2014, 11:49:36 PM by Chad »
Beaup123
    • Cricket Kit Reviews!
Good job Chad! Looks like you've done a great job there,
I wish I had that many bats to muck around with and do "experiments" with.  :(
mp07
Great job Chad!  Quick question...how did you make oval handle for that BAS, did you just put half grip to make it thicker on bottom hand?
Cheers, I was quite surprised at how well the delamination repair on the TON went to be honest! I wish the SS LE repair was that simple haha, that's the bat I am in love with right now!
Haha, the bonus of having plenty if time in my hands and impulse purchases!
Thanks! The ovalling can be achieved just by cutting up a grip to strips, (a thinner grip can be better, as you can then layer) and position it how you want on the handle, then wrap it with insulating tape. Half grip at the bottom only changes the thickness of the handle, not quite the shape!
mattcoll12491
Chad, would you say an orbital sander is the best way to go for a refurbing a bat?
Left-Arm Curious
FvanN
Love the B&S..
mp07
Thanks mate, will try that out for my practice session and see how it feels.
Hi Matt, the best way is probably by drum sander. I only use the orbital to get rid of the residue left by scuff, stickers and glue from repairs, and also for gentle reshaping. I always sand along the grain by hand after using an orbital sander. If I could be bothered to learn how to use white spirit properly, I would still probably use my orbital sander for the sanding after, as it saves a lot of time!
AverageCricketer
  • Colts
Use acetone on the residue. Saves so much time!
mattcoll12491
Thanks for that, I'll have to see if anyone at my club has got one... There's no point me going out and buying one just for one bat!
I've just taken a scuff guard off that had been on for 4/5 years so the bat isn't looking the best at the moment.
Left-Arm Curious
