looking to lose some weight
Author Topic: looking to lose some weight  (Read 4380 times)
The Palmist
  • Trade Count: (+15)
Re: looking to lose some weight
« Reply #15 on: September 01, 2014, 01:11:20 PM »
The whole body burning fat and using carb etc. also depends on your metabolism. Some are just slow burners which means you have to be more stringent with what you eat. You sound like a slow burner.
I won't say cut down on crap, I will say stop it all together.
Speak with Cameronpye on here, I hear he has lost shed loads of weight.
« Reply #16 on: September 01, 2014, 01:46:25 PM »
This slow/fast metabolism is really a load of bunkum.  Some 60% of people are within a range that is considered normal.  This would leave 20% above and below this range,  which would make having a slow metabolism fairly unlikely. There are too many fat people for them all to be part of the one in five that is slow.
Really its about what you eat and how much.  Most people eat a lot more than they need and of the wrong sorts  of food.
The Palmist
« Reply #17 on: September 01, 2014, 02:53:45 PM »
This slow/fast metabolism is really a load of bunkum. Most people eat a lot more than they need and of the wrong sorts  of food.
It isn't bunkum and it will be always be difficult for people to understand this unless they go through with it.
And yes most people do eat a lot more crap than they should.
Metabolism makes a huge difference in tailoring an approach towards weight loss, there is no one size fits all solution here if you want quick and sustainable results. It is about knowing your body and how it reacts to different food, exercise routines etc.
People with different metabolism will deposit fat in different areas, burn fat at a different rate etc...
It is not bunkum but I do say it is not to be used an excuse to continue piling on the crap food and binge eat.
FvanN
« Reply #18 on: September 01, 2014, 03:01:50 PM »
Burn more calories than you consume :) its that simple.
« Reply #19 on: September 01, 2014, 03:45:48 PM »
Metabolism is an excuse used to make sweeping statements and excuses. Metabolism does not determine where you put on weight.
Your basal metabolic rate is influenced by you body’s composition. Muscle requires more energy to function than fat. That’s why men, who typically have a higher muscle mass than women, will generally have a higher BMR than women. Other factors include:
  • height (the taller you are, the higher your BMR will be, due to a larger skin surface area for heat loss)
  • fever and stress
  • smoking and caffeine, and
  • environmental temperature (heat and cold both raise BMR)
A "slow" metabolism is usually found in conjunction with a thyroid problem and requires medical treatment.
Where you put on weight is also not determined by your bmr (i.e. the rate at which you burn calories to survive), but seems (based on sketchy evidence) to be related to genetics and hormones, although there is little conclusive data on this.
Interestingly, fat people have a higher BMR than not so fat people, simply due to their size. The reality is that you shouldn't even talk about "metabolism" when looking to lose weight.
The real answer is burn more calories than you consume and move off a carb rich diet to a protein rich diet with low carbs, so that you move into a state where your body runs on fats rather than glucose. With the latter you'll be surprised as to how much more volume you need to eat if you take carbs out in order to consume the same amount of calories.
« Last Edit: September 01, 2014, 03:49:17 PM by tim2000s »
Howzat
« Reply #20 on: September 01, 2014, 06:29:26 PM »
You're incorrect, Tim2000 is right in his response. To burn fat (adbulwq) as a fuel source your body needs to be in a state of Ketosis (i.e. using Ketones in the blood). This will only happen once your glycogen stores are depleted, which if your are eating regular carbs they wont be. Typically your body will burn ketones during the  night and then glycogen once you've eaten some carbs. This is why intermittent fasting works well, whether fasting daily till say 10am or even longer or fasting 1 day per week for 24 hours.  I'd recommend IF to EVANS1234 as there is no calorie counting and then re assess once your weight is under control.
Although my knowledge came from my degree... I have just googled and here is a website for you that explains that you can lose fat without being in Ketosis
http://www.livestrong.com/article/510136-can-you-burn-fat-without-being-in-ketosis/
ozcfa
« Reply #21 on: September 01, 2014, 09:00:50 PM »
I have become a fan of DVD based fitness programs. I do combination of insanity, t25, p90x3 and UFC fit. Have lost 12/13 kilos in 4 months and feeling v fit. But you can't lose weight without eating healthy.
