Pages: 1 [2] 3 4
Author Topic: My New Bat design "Kalimaar" OR "DW2". Actual bat pictures added...  (Read 19143 times)
mp07
Re: My New Bat design "Kalimaar" OR "DW2". Cleft machined pictures added
« Reply #15 on: August 16, 2014, 02:32:39 AM »
Can do the weight distribution from CAD machine to give you the perfect balance? I guess what I mean is does it give you the % number on weight distribution on the bat instead of you just checking the design visually?
parthnayak
« Reply #16 on: August 16, 2014, 04:45:38 AM »
Will this profile work for low , mud pitches mate ?
« Reply #17 on: August 16, 2014, 08:32:54 AM »
You get a eye for balance or i should say Streaky does we can attain pick up then we can select the handle which is the correct weight.
That's correct we get handles to suit because there variants in there weight too.
Of the bats designed this has a lot going for it in balance terms, Not much weight around the toe and more weight around the shoulders and spine into the handle but not too much away from my hitting area which is big for a 2-8 bat.
Yes you could split the bat in half and find the center of weight and adjust accordingly to improve if you wished but Streaky has the eye.
« Reply #18 on: August 16, 2014, 08:34:47 AM »
It would but i would want the spine maybe going down a tad more towards the toe.
But even on slow low pitches which i encountered in India last year i found i hit the ball still higher than i though.
« Reply #19 on: August 16, 2014, 11:58:55 PM »
You just have a knack of designing profiles I like... :-[ Which of the profiles, DW1 or DW2 has the bigger volume? I think I prefer the DW1, but that may be the ridiculous one Easby is getting that is swaying my judgement!
« Reply #20 on: August 17, 2014, 08:55:26 AM »
Chad not sure i suspect the DW2 might have with the shoulders and big spine in fact a 400 density DW2 would be around 2-12 so they would be pretty similar mate.
« Reply #21 on: August 27, 2014, 06:32:27 PM »
It nearly here a full review will be done not a great looking beast but Streaky has told me it up there with the best they have ever produced and should be a real winner
2-8 and a half...
Inspired by the 1271
spine at top of shoulder 40mm
edge at pinnicle 31mm
He has promised me this will be my number 1 bat due to it performance
Re: My New Bat design "Kalimaar" OR "DW2". Actual bat pictures added...
« Reply #22 on: August 27, 2014, 10:03:38 PM »
Nothing beats 1271 from B3 :P.
« Reply #23 on: August 27, 2014, 10:06:59 PM »
Seems like this is a very slightly toned down 1271 with thicker edges! What would the weight of one of these be with a standard 400 density cleft?
« Reply #24 on: August 27, 2014, 10:41:53 PM »
As the owner of 1271 a true one i tend to agree Uzair it is based on the 1271 with meat all over agree the volume on the 1271 is as big a bat as anything.
Well 2-12 it would come out around mate.
My personal favourite profile made is a mix between Brokenbats and the DW1 and the DB1 but i have quite a few.
Shoab also designed a very nice one too
1271 in crown though is very special
iand123
« Reply #25 on: August 28, 2014, 04:45:02 AM »
Is 1271 the trott bat?
trypewriter
« Reply #26 on: August 28, 2014, 06:56:25 AM »
Very nice looking bat Dave, nice thick handle too. I like the very subtle bow which to me looks more down to handle position than actual bow. Just enough wood off the toe for a nice pick up too?  ;)
« Reply #27 on: August 28, 2014, 11:46:12 AM »
« Reply #28 on: August 30, 2014, 03:51:36 PM »
Nice shape, very similar to the Sirius profile.
As I said looks very different from your bat mate which is also a nice profile
parthnayak
« Reply #29 on: August 30, 2014, 06:33:42 PM »
Dave, you have bat's pic with stickers ?
Pages: 1 [2] 3 4
