Author Topic: Bat wax use  (Read 2115 times)
OwzatOllie
Bat wax use
« on: August 20, 2014, 05:35:28 PM »
Hello all, just a quick one....
I have some Salix bat wax, and I've followed the instructions as per the tin, but I can never get a decent shine from it?
Does anyone have any experience using this stuff and how to use it to get a good finish?
Thanks
Ollie
Re: Bat wax use
« Reply #1 on: August 20, 2014, 07:25:34 PM »
 Apply wax allow  it to dry and lightly buff it in a circular motion with a soft  clean cloth till you get a shine.
mp07
Re: Bat wax use
« Reply #2 on: August 20, 2014, 07:42:23 PM »
How is this better than applying linseed oil?  You get a decent shine from linseed oil too...
Re: Bat wax use
« Reply #3 on: August 20, 2014, 07:53:06 PM »
You are right both will do the job but linseed can make bat fibres softer.
cricketrob
Re: Bat wax use
« Reply #4 on: August 20, 2014, 08:23:11 PM »
I also find wax a lot easier to get an even coat.
Silver Bullet
Re: Bat wax use
« Reply #5 on: August 20, 2014, 11:58:06 PM »
Linseed would also darken your bat.
Re: Bat wax use
« Reply #6 on: August 21, 2014, 12:44:51 PM »
Err. Batoil is majoritarily linseed and has the same effect.
Bambooman
Re: Bat wax use
« Reply #7 on: August 25, 2014, 04:46:24 PM »
The quality of the shine depends largely on the surface you are applying it to. You need to make sure the blade is very smooth. To do this you need to sand it with at least 220(P220) grid and maybe up to 400(P600) for really deep shine. Apply the wax as stated.  Good luck!
