Author Topic: Mongoose mmi3 specs  (Read 6288 times)
Re: Mongoose mmi3 specs
« Reply #15 on: September 02, 2014, 09:22:16 PM »
I made one early on when I first started making for a bit of fun. Was made from a part made and I've had no issues with it. It's actually an absolute rocket! I just left the lower part of the handle a little thicker. Not massively but just a bit thicker. Seems to do ok.
tom line
« Reply #16 on: September 02, 2014, 09:48:47 PM »
That's great new thanks I was a little worried now since someone had brought it up. Do you mind me asking how you cut the shoulders down ? I was planning on using a bandsaw
Thanks
Tom
    • www.cricketinsight.co.uk
« Reply #17 on: September 02, 2014, 10:29:27 PM »
The Mongoose doesn't (or at least didn't) have a reverse splice. In fact the early Kashmir junior bats were made entirely from Adult Kashmir willow bats cut down and shaped here in the UK
Tom
« Reply #18 on: September 02, 2014, 10:43:24 PM »
The bat on the right here is an untwined Mongoose. Hard to see the splice, but it's a standard one I assure you
tom line
« Reply #19 on: September 02, 2014, 10:45:19 PM »
To be fair I always thought the splice was normal but up in the handle
Tom
« Reply #20 on: September 02, 2014, 10:54:17 PM »
Yep that's correct. However, under Appendix E of the MCC laws the blade cannot protrude more than 2.5" into the bound handle area and only 2.75" of the blade can be covered in grip.
To circumvent this law you have to slice through the the 'ears' (where the blade meets the handle) at a certain point. This is why the Mongoose had a large covering of grip tape (which is actually deemed a sticker within the MCC laws) so the cut is actually made closer to 3" from the base of the splice.
The design may have changed, this is the design up until 2011/12.
« Last Edit: September 02, 2014, 10:55:51 PM by Tom »
tom line
« Reply #21 on: September 03, 2014, 08:33:51 AM »
I doubt at the level of cricket I play they're going to question. It but thanks for the info anyway very interesting
« Last Edit: September 03, 2014, 08:36:09 AM by tom line »
