Author Topic: Cricket bat cane handles  (Read 3834 times)
Hobnobs27
« on: October 28, 2014, 12:17:39 PM »
Does the handle make a difference on a cricket bat like a bat that is 5 cane handle compared to a 9 cane handle which one is better.
Also is the 12 piece cane handle like the best bats
Re: Cricket bat cane handles
« Reply #1 on: October 28, 2014, 02:12:14 PM »
In simple terms, the handle makes the bat.
So yes it is really important.
You also haven't mentioned whether there is cork, rubber or other shock absorbsion in the handle too.
The more bits there are to the handle, the stiffer it will be, in theory the stiffer the handle the more performance gets retained through the shot - although other people think having a more "whippy" handle helps them - I suspect it is all in the timing.
better is in the eye of the beholder...
Hobnobs27
« Reply #2 on: October 28, 2014, 06:53:45 PM »
Cheers, so if you compared a sarawack cane handle with a 12 piece handle which ones better
abdulwq
« Reply #3 on: December 25, 2014, 05:28:13 PM »
exactly i would like to know as the handle on new bat broke right after knocking and first time in nets.
Number 11
« Reply #4 on: December 25, 2014, 11:45:40 PM »
Sarawak is a province in Borneo/Malaysia where cane is abundant.
A 12 piece handle contains numerous pieces of cane and rubber and/or cork.
so the answer to which is better is obviously .................................................................................
