Author Topic: Working without a vice?  (Read 3037 times)
TBONTB
« on: November 17, 2014, 03:54:53 PM »
Afternoon,
Any ideas on how to work without a vice? Could I clamp the bat down onto a table? I do not have a garage or anything so I cannot screw a vice into anything. What do you think? Any ideas?
ajmw89
  • 4XI ornament
    • Wright Cricket
Re: Working without a vice?
« Reply #1 on: November 17, 2014, 04:00:16 PM »
Workmate of some variety. Although pad out the plastic jaws with something and weigh the bench down with sandbags if you can
Bambooman
« Reply #2 on: November 17, 2014, 04:06:04 PM »
You could watch some Indian bat making videos on you-tube, that should give you some ideas. If you've got good knees that is.
« Reply #3 on: November 17, 2014, 04:19:00 PM »
DIY stores sell strong plastic clamps they open to around 6 inches and are ideal for clampimg bats  to tables.
Pelican042
  • Best bowling 1-4
« Reply #4 on: November 17, 2014, 06:17:54 PM »
Duncan fearnly used a block on a table and put the handle in his stomach, I think the video is somewhere on here...
"Just remember the best shot in cricket is the leave" *leaves on middle stump*
Lwesty143
« Reply #5 on: November 17, 2014, 06:42:26 PM »
wilkinson's do this one for 20 quid that you can tighten on to any table, and then remove easily.
http://www.wilko.com/hand-tools/stanley-maxsteel-vice-multi-angle-1-83-069/invt/0290122
« Reply #6 on: November 17, 2014, 06:52:12 PM »
I did it without a vice, very tricky but you can push it against a wall and use your gut
sarg
    • CricketBatInfo
« Reply #7 on: November 18, 2014, 10:07:48 AM »
I use a workmate.   Leave the old grips on the bats and clamp the handle. Might get some sand bags. Thanks for the idea.
TBONTB
« Reply #8 on: November 18, 2014, 11:18:18 AM »
I do not think it opens wide enough, it is 75mm and a bat is 108mm wide unfortunately otherwise it would be a good thing.
crictech
    • CricTech
« Reply #9 on: November 30, 2014, 11:27:57 PM »
I've never tried it but you could screw a couple pieces of wood into whatever you're using as a bench at the toe and shoulders and use a wedge to hold the cleft tight although I'd recommend a good vice
Howzat
« Reply #10 on: December 04, 2014, 04:53:08 PM »
You can use your feet to hold the bat... just dont chop your toes off
« Reply #11 on: December 04, 2014, 05:54:52 PM »
Lidi have  one handed bar clamps in store opens to 150 mm 4.99 a pair.
