Pages: 1 ... 10 11 [12] 13 14 ... 16
Author Topic: Australia vs India 4th Test @ The S.C.G.  (Read 40016 times)
Gingerbusiness
Re: Australia vs India 4th Test @ The S.C.G.
« Reply #165 on: January 05, 2015, 03:16:04 AM »
Pressing will be done for total performance, not for durability in the slightest. It will also be an oversized, over-dried and low density piece of willow. Single gripped. It's more than possible.
KP is the same. He just takes a new one out of the wrapper and goes. No prep on his part.
What I find interesting is the stamps... Why are they there?
Gingerbusiness
« Reply #166 on: January 05, 2015, 03:22:23 AM »
Just been looking at pics of Warners old bats - he has definitely changed the shape over the last 18 months.
Jason_Yuan
  • all-rounder bat from 3-8.... high score 66...
« Reply #167 on: January 05, 2015, 04:00:39 AM »
only one changes for the aussie, starc in for johnson, personally think should give Agar another chance...
langer17
« Reply #168 on: January 05, 2015, 04:11:08 AM »
It could also simply be a heavier training bat, like Paul Collingwood used to use.
« Reply #169 on: January 05, 2015, 07:21:10 AM »
I am curious about this. How does the cutting of the cleft result in a lighter but bigger bat? Instead of creating those pie shaped pieces, are you saying that the shape they cut is a bigger slice or block from the tree trunk? If that is the case, there is bound to be more "wastage".
Because the cleff is cut a certain way by the merchants certain sizes are impossible and Becaaue grays cut there own they can create different dimensions.
Take the hell 4leather massive spine bat that would not come from a "normal cleff" but oversized that's my point and yes it will be low density/dried.
As for the size being linked to "performance pressing" but far fetched that.
Also flatter face and sharper edges add around 2-3mm onto the edge and camra angle.
He is a flagship player of course he will get top stuff I would not for once instance think it would be pressed much difference to anybody else's bat at all.
Bar size players bats 90 per cent of the time are the same we get bar size to weight ratio. People talk about mythical things but there simply not there.
As for this performance pressing thing well that simply is not the case mate as we are looking for stiffness in the blade which is a different thing.
My theory on bats is simple get a handled cleft unshaped but pressed bounce a ball on it you will understand then about vibration and stiffness in blades.
« Last Edit: January 05, 2015, 07:26:51 AM by procricket B3 »
Gerry SA
  • Voice of the Voiceless
« Reply #170 on: January 05, 2015, 11:06:44 PM »
Steven Smith wins the toss and elects to bat.
One change for Australia, Johnson out Starc in.
FOUR changes for India:
Out: Dhawan, Pujara, Dhoni & Ishant
In: Rohit, Raina, Saha & Kumar.
KL Rahul up to opener, Rohit at 3, Raina at 6.
"You should never get nervous about anything. What today seems important tomorrow isn't so any more."
Tito Vilanova (17 September 1968 - 25 April 2014)
Gerry SA
« Reply #171 on: January 05, 2015, 11:10:41 PM »
Ishant was named VC and promptly dropped #HeadsGone
Pujara axing was justified as he's failed to live up to the hype in NZ, ENG and OZ
Gerry SA
« Reply #172 on: January 05, 2015, 11:16:00 PM »
Veteran Chris Rogers playing his final Test match in Australia, would be nice for him to bag a 100
« Reply #173 on: January 05, 2015, 11:18:09 PM »
Interesting, then, that Warner chooses to oil his bats? Not many pros do.
« Last Edit: January 05, 2015, 11:41:24 PM by Bats_Entertainment »
« Reply #174 on: January 05, 2015, 11:21:49 PM »
I heard Ian Botham make this mistake on TV. No-one questioned him, obviously. ;)
Sam
« Reply #175 on: January 05, 2015, 11:25:20 PM »
Brilliant tribute to Hughes there from Clarke.
sayed
« Reply #176 on: January 05, 2015, 11:54:03 PM »
Raina didn't play a single First Class or Test match in 2014 and he is playing!  :o
Gerry SA
« Reply #177 on: January 06, 2015, 01:23:35 AM »
Rogers and Warner pounding the Indians into the dirt in the first session. 118-0 off 25 overs!
Shocking bowling by the Indian seam bowlers and KL Rahul dropped a clanger in the slips as well.
i12breakfree
« Reply #178 on: January 06, 2015, 05:20:52 AM »
Poor captaincy with too many bowling changes from kohli are not helping.
Hope he will learn from all this .
Steve smith is playing at a different level all together - an unforced error looks to be the only way he can get out.
« Last Edit: January 06, 2015, 05:41:13 AM by i12breakfree »
« Reply #179 on: January 06, 2015, 05:34:38 AM »
I am day dreaming of a bat like that.
