Author Topic: How I added weight to my mallet  (Read 1383 times)
« on: December 16, 2014, 08:19:05 PM »
Evening all
Following on from an earlier thread, here's how I added weight to my mallet.
I drilled holes and added lead fishing weights, will see if this lasts or if I wasted my fishing weights!
I started off making a hole for my lead fishing weights to go in.
This resulted in a lot of smoke and not a lot of progress...
Finally got a hole in there
And added a 3oz lead weight.
I tested it fit first
Then stuck in there with shoe goo
And wiped away the excess goo
As it went too smoothly I added an extra 1oz underneath
Which cracked the mallet, so I added a dowel
Finally I covered my mess with some tape!
At the end of all that the mallet is 497g, whick is still 138g lighter than my mallet/cone combo. D'oh!
Re: How I added weight to my mallet
« Reply #1 on: December 16, 2014, 08:30:05 PM »
I use the  standard light mallet and it regularly cracks my new bats. My recent Red Ink has many cracks on the bat face. Am I hitting too hard or do I need a mallet with a larger head for an even contact?
« Reply #2 on: December 16, 2014, 08:32:27 PM »
Do you oil to bat first?
Could be knocking too soon after oiling.
Could be hitting too hard too quickly.
Could be a new mallet required.
« Reply #3 on: December 16, 2014, 09:00:32 PM »
All bats should crack.- not split
Hit the face evenly edges  at  a 45 degree angle.
Don't knock the bat in when it is wet
Don't knock the bat in when it is very dry.
« Last Edit: December 16, 2014, 09:06:55 PM by Seniorplayer »
i12breakfree
« Reply #4 on: December 16, 2014, 09:02:22 PM »
^^ that's a lot of work for adding 4 oz. Knocking is a pain though irrespective of how much ever it brings one closer to his bat [emoji12]
