Author Topic: T20 Bat B3 shoulder tests...  (Read 2195 times)
« on: December 19, 2014, 08:44:49 PM »
Well after turning up at B3 i told streaky i was after looking at the T20 area and what could be done with bats in this area which has not already been done.
We came up with a crude yet experimental thing cut the lugs off and have basically a square shoulder so you could get further down the blade making it a touch lighter and a bit different pictures to follow ....
Re: T20 Bat B3 shoulder tests...
« Reply #1 on: December 19, 2014, 08:49:23 PM »
Oooooh! Helloooooooooooooooooo!
« Reply #2 on: December 19, 2014, 08:50:17 PM »
cattus brackus,,,
Pictures to come
« Reply #3 on: December 19, 2014, 08:54:27 PM »
I have a b3 styled t20 bat.......
Intrigued what you've come up with though,
« Reply #4 on: December 21, 2014, 09:50:44 AM »
Any pics yet dave?
« Reply #5 on: December 21, 2014, 10:08:13 AM »
Nothing like your one this is crude and off the cuff mate..
Bet the saw out time. Truth is this cleft had a crack in the fitting stage so i thought of a plan about getting as low on the handle so as the crack has been cut out and hey presto you can get lower on the handle a crude yet simple way. I couldn't let this bat just gather dust or be cut up. Taps up very well and can see too many issues but will be testing it in the nets.
I may get one made up but because of the angle will have to have the shoulders or stump polished before handle fit as this is a rough job....
« Reply #6 on: December 21, 2014, 10:09:50 AM »
Crude but i like the idea in a non scientific way ..
« Reply #7 on: December 21, 2014, 10:31:33 AM »
How much did you drop the shoulder by? In mm.
And what's the final weight??
« Reply #8 on: December 21, 2014, 10:32:43 AM »
Not too drastically different it will draw attention, while still managing to be a unique design, I like that!
« Reply #9 on: December 21, 2014, 12:32:25 PM »
Weight is around 2-9 and the drop is about 4mm ish
