Author Topic: Spartan repair  (Read 1318 times)
tom line
Spartan repair
« on: March 01, 2015, 09:39:31 PM »
Recently got asked by a friend of mine whether I could repair this spartan he had the whole corner had come off the bat but luckily he had kept the piece so made the repair slightly easier
I then glued back in the piece
After this I sanded the whole bat down so the fix was flush.
After this I dowelled the bat with 3 dowels (2 from the edge and one through the toe)
Then final sanded and polished the bat. I binded the tow just for the added security and taped over it.
Here is the result let me know what you think.
Re: Spartan repair
« Reply #1 on: March 01, 2015, 09:47:15 PM »
If you put two dowels through the edge and one up the toe, wouldn't you be drilling through some of the dowels you'd already put in?  ???
tom line
Re: Spartan repair
« Reply #2 on: March 01, 2015, 09:58:24 PM »
No I made sure they didn't pass through each other. Two went high through the crack on the edge and one at a low angle through the toe
