Thoughts On GoPro 4 For Cricket Nets
Pages: 1 [2] 3
Author Topic: Thoughts On GoPro 4 For Cricket Nets  (Read 13065 times)
Re: Thoughts On GoPro 4 For Cricket Nets
« Reply #15 on: January 02, 2016, 12:18:10 AM »
I have a Garmin Virb Elite that I've used for cricket a few times, good alternative. Cost me about £120 from memory? Video quality is spot on with a bunch of extra features that don't make much difference for cricket but are very useful for other stuff. Live view on the screen and zoom mode which I think is a big advantage over GoPros.
Link to video (think I filmed this in 720p rather than 1080): https://youtu.be/qqNgV9NKT8U
« Reply #16 on: January 02, 2016, 12:25:26 AM »
Just looked and the basic model (same image quality but without WiFi connectivity) is on Amazon for £75 atm, would snap one up at that price! http://www.amazon.co.uk/Garmin-Virb-HD-Action-Camera/dp/B00EQ2T3KQ
StillNotOut
« Reply #17 on: January 02, 2016, 12:40:20 AM »
Saw these on Amazon earlier which could be a cheaper alternative?
Sports Camcorder Blue Underwater Waterproof Camera, Sports Action Bicycle Helmet Car DVR Recorder 12MP HD 1080P Wide-Angle Lens + Variety of Stands/Mounts/Casing for Skiing, Snowboarding, Surfing, Hiking, Climbing, Extreme Sports (Blue) https://www.amazon.co.uk/dp/B00N3Y9J84/ref=cm_sw_r_cp_awd_fVXHwbA3SB0M5
DBPOWER 1080P Waterproof Action Camera DV 12MP HD DVR Camcorder + Mounting Accessories Kit https://www.amazon.co.uk/dp/B00J02XVYG/ref=cm_sw_r_cp_awd_CWXHwbZH9Z0DB
Liam-SCCC
« Reply #18 on: January 02, 2016, 01:17:08 AM »
I have just got the GoPro Hero 4 session because they dropped the price! But haven't had a chance to use it for cricket yet! Did some stuff last year with my hero 3. The problem I found with GoPros is their 'range' when mounted on the bowlers end stumps the batsmen is quite far away! Meaning you have to zoom in in editing, which reduces the quality!
Here is an example of it from the bowlers end, I know it isn't that good because I had it mounted at the bottom of the stumps but it gives you an idea. https://youtu.be/WoFvAedhqn8 The lighting was OK in the nets (indoor school at county ground Taunton) but the GoPros do best with bright natural light.
The GoPros do better capturing what's going on in front of them or coming towards them. Here's a video I took with the GoPro mounted behind the net. https://youtu.be/2F-mgEfwZ6E
Here is one of my better net videos, using the GoPro as a helmet cam and then my DSLR on a tripod way back behind the stumps using a 70-300mm lens. https://youtu.be/_SXMGk5d9o8 (yes I do leave 2 straight ones in this video! Followed it with 48 not out on the weekend though!)
Hope that gives an idea of how you can use the GoPro and what its strengths are, I'd say it's better mounted on the helmet or inside the net looking at the batsmen for cricket stuff. Having it mounted on the stumps at bowlers end doesn't give you the best view of what's going on. I did do a club video where I had it on the umpires head, that hasn't made it onto YouTube yet mainly because I'm unhappy with the quality of the footage, overcast skies meant not the best light and the umpire cam being a little too far away.
The newer GoPros do have a choice of field of view where you can change the wide view for a medium or narrow one. This would give it a more 'zoomed in' effect. This could be better for cricket but I haven't had a chance to try that out yet, maybe simmy has been able to?
Top Score: 102*
Best Bowling: 7/29
Woodyspin
« Reply #19 on: January 02, 2016, 01:54:26 AM »
3:35 is you best shot. Id say you use too much bottom hand in most shots
Sent from my LG-H815 using Tapatalk
rickjames
« Reply #20 on: January 02, 2016, 01:55:54 AM »
Hmm, someone on another forum is selling a Hero 3 Silver for £90inc P&P. Tempted to dive in...
Jaffa
« Reply #21 on: January 02, 2016, 09:25:19 AM »
A while back I bought a Drift Ghost-S instead of a GoPro. My decision was based on frame rate, battery life and the shape of the thing. It is more bullet like than a GoPro brick shape. I do though use the free GoPro software to edit.
It doesn't look like they've updated the Ghost for a while so maybe there are some bargains to be had.
HallamKeeper
« Reply #22 on: January 02, 2016, 05:35:22 PM »
I got the hero 3+ mainly for nets. I also got the accidental damage cover for £20. I first tried it attached to the bowling machine but due to the light and distance it wasn't the best picture. I then tried it about 5m ish from the bat on which ever side I thought would be safest. Just using a lightweight tripod made from plastic so hoping if I do hit it, the whole thing will just tumble rather than break. Plenty of accessory packs on amazon for £30 with everything you could ever need.
I only went for the gopro for the durability. A hockey keeper wore one on his helmet in training and we managed to hit it, camera survived but the helmet clip snapped. Was contemplating using it to record an innings (or as much as the battery will last for) when the season starts. Probably tie it to the sight screen as our ground is small.
rickjames
« Reply #23 on: January 02, 2016, 06:00:31 PM »
FWIW if this guy can't break one then I don't think anyone can
« Reply #24 on: January 02, 2016, 06:07:06 PM »
I tried to
rickjames
« Reply #25 on: January 02, 2016, 06:10:37 PM »
And it lived! Textbook accuracy
peristocle
« Reply #26 on: January 04, 2016, 11:21:18 AM »
Thinking of getting a Hero 4 session for an upcoming tour of Sri Lanka.
Anyone used one for Cricket?
rickjames
« Reply #27 on: January 04, 2016, 12:02:30 PM »
I wanna bite on it but reading through I'm not sure if the housing could be able to handle a direct hit at speed from a ball, which the Hero 4 in the houses probably can...
HallamKeeper
« Reply #28 on: January 05, 2016, 12:53:09 PM »
On a slightly different note, where do you get the dummy batsman that was in the video (the first video)? Would be useful for keeping practice when you don't have any mates to obscure your view.
rickjames
« Reply #29 on: January 08, 2016, 02:23:36 PM »
So yeah, I just bought a Hero 4 Silver on Amazon. The 'Adventure' Edition is on sale with a 32gb SD card included, my eyes suggest it's exactly the same as the regular Silver, but maybe a mount or two extra? Seems decent for the price when it normally retails alone at £250 http://www.amazon.co.uk/gp/product/B015JHPAOO/?tag=ho01f-21
p.s Oval netting buddies, get your practice in for Wednesday, haha.
Pages: 1 [2] 3
